Originally Posted by Bad Luck
Not sure if you're aware of this but when you press the 4wd button it is supposed to put you in High 4 Locked which you aren't supposed to use on hard surfaces. That beeping is telling you that you're going to fast to engage 4wd and need to slow down. I would find a dirt lot and do some figure 8's while engaging 4wd. Report back with results
Thanks for the tip. I tried this for a good 20 min today. I could not detect anything happening mechanically, nor were there any lights.
Could the gears be stuck 4wd? the way the truck makes sharp turns (tail swings into turns) makes me believe that 4wd remains engaged.
P.S. the 4wd lever has a steady vibration it it. The vibration becomes very intense for a short moment as it passes from one position to the next. Could this be indicative of something?
