Old 02-16-2020, 07:10 PM #1
estoe estoe is offline
estoe is on a distinguished road
Key won’t completely turn to “Lock”
Hi, couldn’t find this specific problem so...
Sporadically, & not relative to anything consistent, my key will only turn off as far as the “ACC” point on ignition switch. If I disconnect the battery, I can then turn off all the way & pull out the key. I replaced the ignition switch (just the tumblers), but the problem remains. I assume it’s something electric relative to steering wheel lock or otherwise? Any advice appreciated. Thanks
estoe is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 08:28 PM #2
4flyer's Avatar
4flyer 4flyer is offline
4flyer is on a distinguished road
4flyer's Avatar
I am currently having the same issue. I believe the problem is with the sensor that detects that you are in park. It is to prevent you from turning the car off all the way when not in park. So, somewhere along the line, there is likely a loose connection. I am getting around it by shifting into park very slowly and that is working well enough until the problem gets worse or I get time to tear things apart.
2001 Limited 4x4 Black/Tan
4flyer is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 09:09 PM #3
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
It needs to be in park to be able to go to off
plcfcng is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 09:40 PM #4
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
He's right. It's the shift interlock solenoid that's going out on you.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 02-17-2020, 01:53 AM #5
Wow- that makes so much sense. Not sure if it’s coincidental or not, but I was able to operate the key correctly after I unplugged the 2 wire connection to to the ignition switch. I assumed this was an off/on circuit that made the “ding” go off when the key would be left in ignition & door was open. No idea why this would affect operation, but it did tonight & I'm going to drive it awhile & see if the sporadic problem returns. If so, will direct attention to park sensor & see if there’s a problem there before pulling trigger on new ignition assembly. FWIW, I did try that previously (shifting into park a variety of ways & wiggling it once in position), but it never affected the problem. Just comes & goes mysteriously. Thanks for input!
Old 02-17-2020, 09:03 AM #6
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad is just really nice sleepydad is just really nice sleepydad is just really nice sleepydad is just really nice sleepydad is just really nice
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
you also might try this... I have exactly the same problem and this is how I got around it.
Old 02-17-2020, 11:04 AM #7
Great vid- that’s the problem w mine. It worked by disengaging the 2 wires to ignition that are separate from the 7 wire harness (on my 02), but it triggers engine check light as well. Disengaging the solenoid did it. Thanks!
Old 02-17-2020, 10:25 PM #8
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
cool beans, glad it helped.
ignition , key , problem , relative , turn
Turn off the auto-lock feature? Robb235 3rd gen T4Rs 20 04-18-2018 07:43 PM
Key won't turn driver door lock Qyota 3rd gen T4Rs 20 08-09-2017 08:31 PM
Trying to turn off auto door lock drftingfromshor 4th Gen T4Rs 5 06-30-2015 06:53 PM
Power Lock Works... But Not Completely TiN 4th Gen T4Rs 4 11-07-2013 11:35 AM
On Lock / Unlock, turn on headlights for 30 seconds savesheep 4th Gen T4Rs 1 04-28-2008 10:06 PM
