Originally Posted by 4restGump
Thank you.
Swapping the harness over, is that meaning swapping the harness from the 99 tailgate over to the 98 tailgate?
Correct which ever harness and modules that matches the truck. Looks like your is a 99 and the replacement is a 98. So yes the 99 wiring and modules into the 98 tailgate.
The chassis are the same [ shells of the tailgate]
If the witing doesn't match. Be very careful and make sure they are compatible. Plugs not matching definitely means they don't. Extremely common in Toyota to change connectors on circuits.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
