Old 02-17-2020, 11:49 PM #1
ShannanC's Avatar
ShannanC ShannanC is offline
Real Name: Shannan
ShannanC is on a distinguished road
ShannanC's Avatar
Real Name: Shannan
Unhappy P1780 issue with a “special” twist
I have the P1780 Neutral safety switch issue, but with a “special” twist. The check engine light came on the other day and my HVAC controls decided to change from Fahrenheit to Celsius! I had one hell of a vibration from a universal joint that was about to crap the bed and I believe that the vibration might have added to the issue. I had overlooked the universal because my upper control arms were failing and they had in turn caused my tie rod ends to prematurely wear which caused the front end to vibrate like crazy. All of this happened as I am working Nights and a lot of 12 hour shifts so I’m not exactly on my game at the moment. But..wait..it gets better! Now my truck won’t shift but once. I can move the shifter into any gear and the HVAC display stays in Celsius except for 1st gear where it changes back to Fahrenheit.
I bought another neutral safety switch, but after reading up on the issue I don’t believe that this will solve anything because the truck starts and runs fine. I changed the universal so the vibration is gone except for the front end wiggle which I will repair after I get it to shift again.
I also noticed yesterday as I played with the shifter that the instrument cluster is starting to glitch out with the gear indicator on the dash. I was contemplating changing the printed circuit board.
I apologize for the long ramble.
If anyone has any comments or suggestions I would be very grateful!
99 4runner Limited 2wd - K & N air filter, deck plate mod, ISR mod, 2" Fat Pat's body lift, Bilstein Tundra 5100s and Toytec 620lbs coils in front, LX450 coils and Bilstein Tundra 5100s in rear, extended end-links and panhard drop bracket, Maxxis MT-762 Bighorn 255/85/R16, JDM engine swap, sport hood, ARB front bumper, 199mm Tundra brake upgrade
ShannanC is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 08:59 PM #2
ShannanC's Avatar
Real Name: Shannan
ShannanC's Avatar
Real Name: Shannan
Bump
Anyone?
Old 02-18-2020, 09:03 PM #3
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
Intermittent grounds can cause a whole range of seemingly unrelated
problems.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 09:10 PM #4
ShannanC's Avatar
Real Name: Shannan
ShannanC's Avatar
Real Name: Shannan
Thank you for the input. I will start checking.
Sent from my SM-N950U using Tapatalk
Old 02-18-2020, 10:02 PM #5
SusVir SusVir is offline
SusVir is on a distinguished road
I had the exact same issue on my 4Runner ('99 Limited A/T). After a lot (A LOT) of troubleshooting and reading online, I narrowed it down to the Instrument Panel Circuit Board (Part 83861-3D260). It's the blue "sheet" that sits behind the gauges (2:40 in the video). Turns out after twenty years and 300k miles, some contacts wore loose or something, I don't know. Anyway, I replaced that and voila, it solved all those problems! Here's a video from Timmy the Toolman that should help you remove the guages. And another VERY helpful link from smallfry from the T4R forum. Good luck!
YouTube
Transmission Issue????
Sent from my Pixel 3 XL using Tapatalk
SusVir is offline   Reply With QuoteReply With Quote
Old 02-23-2020, 10:31 AM #6
ShannanC's Avatar
Real Name: Shannan
ShannanC's Avatar
Real Name: Shannan
@SusVir
I changed out the circuit board last night and it fixed the problem. Thank you very much.
caused , gear , issue , universal , vibration
p1780 cel park neutral switch error with erratic dash indicator lights Mountain Fun 3rd gen T4Rs 3 11-14-2023 02:50 PM
P1780 woes OBTDean 3rd gen T4Rs 0 01-23-2017 03:33 AM
Starting issue with a BIG twist adder70 4th Gen T4Rs 1 11-01-2016 02:39 AM
Starting issue with a BIG twist adder70 3rd gen T4Rs 1 10-31-2016 11:55 PM
P1780 Check engine nissanh New Members 6 10-05-2016 04:23 PM
