Old 02-18-2020, 02:21 PM #1
INDwinak INDwinak is offline
INDwinak is on a distinguished road
HELP: where does this bolt go?!?
The videos and posts found throughout this forum have given me courage to start wrenching on my 96 4runner 5VZ (with AT).
This past weekend was my second time ever taking a wrench to it. I replaced the front brake hoses, changed the oil, and drained and filled transmission and power steering.
When cleaning up, I found a bolt on the floor that I don’t recall taking off (pictured below) by the front driver-side tire. I am a bit freaked out. Does anyone recognize it? It doesn’t look like any I saw elsewhere on the T4R. Maybe it was laying on my skid plates from a previous repair? (I had the starter worked on in December).
Any ideas would be appreciated. I didn’t find anything (obviously) missing a bolt. I’m afraid to drive it with a missing bolt!
HELP: where does this bolt go?!?-dd78-ac6-c-ea3-e-4-d29-82-b0-04-e883210053-jpg  HELP: where does this bolt go?!?-c777422-b-bd27-48-b9-820-f-9-a09-dfbbb424-jpg
INDwinak is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 02:24 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Looks like a timing bolt cover bolt. Plastic timing belt cover. See if this bolt matches it.
Old 02-18-2020, 02:25 PM #3
plcfcng's Avatar
plcfcng plcfcng is online now
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
the timing belt cover either the top part above the fan or the lower part behind the crankshaft. Find a picture of these parts as there are a couple of hole that are hard to find.
plcfcng is online now   Reply With QuoteReply With Quote
Old 02-18-2020, 02:37 PM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Definitely one of the upper timing belt cover bolts. The one on the bottom left is the hardest to see.
Old 02-18-2020, 03:21 PM #5
Thanks all! Hopefully this is something that I can put back without having to take off the belts, fan, or radiator.
Hopefully I can find the process and torque spec somewhere in the FSM.
Old 02-18-2020, 03:51 PM #6
HiLife HiLife is offline
Yup. Bet the bolt fell onto the topside of the the skid plate during a previous repair.
Old 02-18-2020, 08:05 PM #7
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
No you should be good. A flashlight or a small mirror helps since some of the bolt locations are a little tricky to see looking straight down. I attached the page from the FSM. There's 6 bolts total and they are torqued to 9 N·m (90 kgf·cm, 80 in.·lbf). That's essentially just a tad tighter than finger tight, only snug enough so it doesn't fall back out again.
326WHP 347TQ
Old 02-18-2020, 08:55 PM #8
Yep, that was it. It was the one on the bottom left.
Was able to get it with a deep socket and a torque wrench. Will check the rest of them in the AM for proper torque.
Thanks all! So helpful.
bolt , found , front , missing , taking
What is this bolt? csommers 5th gen T4Rs 2 04-12-2019 05:44 PM
Steelcraft Bull Bars - 2 Bolt vs 4 Bolt Versions 4runnator 4th Gen T4Rs 4 07-04-2017 11:07 AM
Where does this bolt go? wmswords 3rd gen T4Rs 12 08-24-2015 11:04 PM
Bolt Help...Please? SFnatt 3rd gen T4Rs 5 07-07-2014 06:24 PM
Body Lift Block ID/Bolt length- Steering Shaft bolt length 02_SE_Runner 3rd gen T4Rs 6 03-15-2013 09:57 AM
