Old 02-19-2020, 08:52 AM #1
femonav femonav is offline
femonav is on a distinguished road
Help Needed - Coil Springs
Hi guys.
I need your advise/recommendation. I bought for my 4Runner 2000 Limited 4WD the following:
2 x KYB SM5184 Strut mount
2 X Bilstein 24-248730
2 X Bilstein 24-249966
Do I need to buy any additional parts?
Which coil springs do you recommend?
Thanks for your help Help Needed  - Coil Springs
Enviado desde mi iPhone utilizando Tapatalk
femonav is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 01:48 PM #2
If you are happy with the current ride height, keep your current springs. If not, what is the measurement from the center of your hub to the fender lip on each corner and how much do you want to lift it?
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-19-2020, 02:14 PM #3
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Lots of options. Depends on what you want to do.
My personally, I like to maintain down-travel articulation so I don't lift the front much. Perhaps 880s are fine for you if you want some lift? Or you can get the "highland edition" coils. They are like stock but an 1" taller if I am not mistaken. Great if you want that oem ride vs a firmer ride.
I'm debating on trying some 1st Gen tundra trd coils on my tundra 5100s. I have 880s now and the ride is rough with these shocks to me. But rough to me may not be rough to you, vice versa.
Are you getting 4runner specific 5100s?
As for the rear, I personally would go well with the 890s. I had 906's but they were too short. With 890s and tundra 5100s my rear flex is crazy. (To me at least)
Also, make sure to extend the brake lines. Might as well flush the system when you swap the lines
Lately, change the front upper and lower ball joints if you have not already. Critical maintenance items!
Old 02-19-2020, 08:19 PM #4
Thanks Charlie. I want to lift it no more than 3”. The intention is also to have a comfortable ride.
Any suggestion?
Old 02-19-2020, 08:25 PM #5
Thanks for the advise jross. Yes I have the 5100 Bilsteins made for the Toyota 4runner 3gens.
I wanted to lift it a little bit, no more than 3” and lookink for comfortable ride as well.
Any suggestion
Old 02-20-2020, 09:44 AM #6
jross20's Avatar
jross20's Avatar
Any suggestion
Well, it's up to you but just remember that the higher you lift the more down travel you lose. As in, how far the wheels can travel down. I believe stock is up 4 down 4. With my tundra 5100s up front and the 880 coils I actually have 4" of down travel since the Tundra 5100s are a wee bit longer.
If your don't want much lift and want comfort, I would get the Highlander edition coils. Not the vehicle called the Highlander, there was a third gen 4Runner that was called the Highlander edition and it sat 1" higher.
Another could be other coils that might be a better option, these are just the only ones I am aware of.
Old 02-20-2020, 12:22 PM #7
4runnerfiend's Avatar
4runnerfiend 4runnerfiend is offline
4runnerfiend has a spectacular aura about 4runnerfiend has a spectacular aura about
the "highlander" coils are mostly called 99 talls. They are found on pretty much all 1999 4runners although i'm sure there are exceptions. The alternate to these 99 talls is 5th gen springs. You will yield about the same amount of lift IE 1" but they are way easier to find, and typically will have way less miles. I literally yesterday just swapped out my 99 talls for a set off a 2016 SR5. They are installed on the 4th perch of Tundra 5100's and I've got over 23" hub to fender. I'm sure they will settle a little.
IG: @4runnerfiend- 1999 SR5: TRD Supercharger, ELocker, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, DuroBumps, RidgeGrapplers, Doug Thorley Headers, yellow top, XRC 12k, ARB single compressor.
4runnerfiend is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 02:32 PM #8
Any suggestion?
Stay well below a 3" lift if you want comfortable.
Unless you are going to carry weight, go with new OEM "99 Tall" springs in the front and then choose rear springs that will work with what you want (rear 99 Talls, OME 2890, OME 2906, or FJ Cruiser or 5th gen 4Runner springs)
A body lift will also help you get visual height (and body clearance for larger tires) with no loss of comfort.
Old 02-22-2020, 10:29 AM #9
mattman's Avatar
mattman mattman is offline
mattman is on a distinguished road
mattman's Avatar
Where can you get new OEM 99 springs?
I have a 2000 that is fine, but recently got a 2002 that sits lower.
2000 4Runner SR5
231mm brake upgrade
KYB shocks
2002 4Runner SR5
99 Tall Coils w/ KYB shocks
mattman is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 10:38 AM #10
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
New? Dealer.
Used? Classifieds here (and other places), parts yards, etc...
Aftermarket? You said OEM... so, nope.
Brian. is offline   Reply With QuoteReply With Quote
bilstein , buy , coil , parts , springs
Urgent help needed: Ignition Coil Bolt Sheared j_h_cole 4th Gen T4Rs 9 08-13-2018 07:55 PM
Boss coil over advice needed direwolf74 3rd gen T4Rs 3 07-19-2015 10:25 PM
WTB:NEEDED rear coil isolator camdz Want to Buy/Trade 0 05-19-2015 10:53 PM
Icon overland coil spring info needed Brutalguyracing 4th Gen T4Rs 10 08-03-2014 11:13 PM
Rear Coil springs for 3rd gen (replacement recall springs) stevesnj For Sale: Suspension/Wheels/Tires 0 07-20-2013 10:57 AM
