Old 02-20-2020, 09:40 PM #16
cahilc cahilc is offline
cahilc is on a distinguished road
Originally Posted by bugkillr View Post
I've heard using diesel oil in a gas engine can lead to clogged catalytic converters over time. Supposedly due to the "add pack" diesel oils use.
That's primarily due to ZDDP in the oil formulation. ZDDP is a physical lubricant. Since the 2007 EPA mandate to reduce levels most manufacturers have dropped ZDDP levels for gas but keep levels high as possible for diesels. They've been replace with chemical lubricants.
FWIW... Any additive to an oil package that I've seen actual data on lubricity has trounced the oils lubricating capabilities. The oil formulations are extremely tight these days.
If you want some good reading on oil packages (and why not to use additional oil additives) jump over to TRD (Turbo Diesel Review). Gonna find some interesting info. A lot of the expensive 'boutique' oils crash and burn.
2002 Sport Edition (Big Red) 2wd auto, 235k
cahilc is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 09:53 PM #17
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
I do not use sea foam in the engine oil .. good if you have a fuel injection issue put it in the gas...
I use marvel mystery oil in my old 25 plus year old engines because I do not use synthetic in those motors...
I only put in 1 oz per quart of oil cap.. of MMO.. one engine has 5 qts so 5OZ of MMO.. this will slowly breakdown the sludge and clean up the pan and oil filter screen.
you said a small amount of sludge on the heads.. so looks like you do the oil changes properly. on all my engines I do the oil changes and run the engine for several miles so it is hot.. then I give it 45min for all the oil to drain out.. I would cut open the oil filter so that the filter media looks good..
catrains is offline   Reply With QuoteReply With Quote
curious , i’m , oil , seafoam , true
Seafoam or not to seafoam that is question? CreteDog401 3rd gen T4Rs 16 07-03-2015 04:01 PM
Seafoam? James_T 4th Gen T4Rs 23 01-17-2014 11:57 PM
SeaFoam V8 - Need Help Here... jlm6985 4th Gen T4Rs 5 06-26-2011 03:44 PM
seafoam marcel 3rd gen T4Rs 12 10-27-2010 04:44 PM
Where to Seafoam on 4th Gen V6? Border411 Maintenance/Detailing 5 03-08-2010 05:37 PM
