Old 02-21-2020, 10:53 PM #16
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
Originally Posted by Capnemo View Post
I appreciate all the posts but no one really answered the question about whether modern fill synthetic oils tend to leak less.
It is my understanding that once a synthetic (or any) oil has found a way out, changing back will will not stop the new seepage, hence the advice against changing to full synthetic oil late in a vehicles life that has only had dino oil.
I am also not about to try to cure the leaks in this vehicle, it not that brisk but also likely not from just the valve cover gaskets. But if they got worse with a
fully synthetic oil I would be pissed. And seitching back to my current oil, from many reports, would not return to my current leak rate.
It will not cause leaks! Switched to synthetic around 200k and Penzoil Platinum around 224k, no leaks. Most synthetic oil has some conventional oil in in and all conventional oil has some synthetic in it. Replace your valve cover gaskets. Did mine with FelPros 60,000 mile ago, no leaks.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 12:22 AM #17
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Since 1998, I've bought 4 Toyota trucks that had about 100,000 miles on them and then switched them to synthetic. No additional oil leaks have ever occurred.
pluton is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 09:53 AM #18
sawguy50 sawguy50 is offline
sawguy50 is on a distinguished road
I switched over to Mobil 1 about 2 yrs ago with around 240k miles. I use about a quart in 10,000 miles (not leaking). Change every 10,000 miles with a Wix XP filter. Mobil 1 High Mileage formula 10-30. I do this in all my vehicles with no leaking at all.
sawguy50 is offline   Reply With QuoteReply With Quote
Old 02-23-2020, 09:20 AM #19
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
FWIW.
Like others stated the leaks are caused by warn out seals. Since synthetic is more thinner it can leak out. The benefits of synthetic vs conventional far exceeds the seeps. If the leaks are significant. You could always use 10w-30 synthetic oil until the seals are replaced. Then drop down to 5w -30.
Or run a synthetic and conventional blend.
full , mileage , oil , synthetic , torqued
Will switching to synthetic in high mileage cause oil leaks in the future? jdotlim 4th Gen T4Rs 11 04-29-2016 01:27 PM
100k + Oil Changes. Conventional, synthetic blend, full synthetic? Jeffrey_VB 4th Gen T4Rs 17 01-12-2016 01:50 PM
difference between full synthetic and synthetic blend chetJ 5th gen T4Rs 20 07-18-2013 09:08 PM
Synthetic oil in high mileage engine mreloc Maintenance/Detailing 29 03-29-2013 03:58 AM
synthetic brake fluid and full synthetic powerstering johnathandm 3rd gen T4Rs 3 07-20-2011 10:35 AM
