Old 02-20-2020, 08:49 PM #1
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
17" Wheels on unlifted 2000 LTD?
An opportunity came up to grab a set of 17x8 wheels from a friend that will fit this rig. I was about to buy a set of AT 16" tires but am wondering what 17" tire dimension I could fit in the unlifted wheel wells if I get these wheels? I plan to do a spring lift later on, but for now, l will leave the suspension alone. I will never be a serious crawler, mall or trail, so the small benefit of sticking with 16" wheels for serious off-roading isn't that big a deal. I do a lot of forest service roads, nothing very aggro. Mainly asking what rubber I could fit without rubbing.
Thanks!
Old 02-20-2020, 08:57 PM #2
ColoRockyT4R's Avatar
ColoRockyT4R ColoRockyT4R is offline
Real Name: Alex
ColoRockyT4R is on a distinguished road
Real Name: Alex
I just put on a set of 4th gen sport wheels on my bone stock 2000 limited with o/e size tires and they fit great with absolutely zero clearance issues
1996 4Runner SR5 4x4 - 3” lift, 32” tires, Toytec Boss rear shocks - Bilstein front’s, Energy Suspension Poly bushings. - SOLD!
2000 4Runner Limited 4x4 - New project w/ locking rear diff.
ColoRockyT4R is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 09:07 PM #3
Ricktuk Ricktuk is offline
Real Name: Rick Tuk
Ricktuk is on a distinguished road
Real Name: Rick Tuk
The wheel doesnt mean as much as Wheel tire height combination. Put low profile tires and the total circumference wont be as much as stock. put tall tires on stock rims and it will rub. Just think a little. But 17" shouldnt have a problem
Ricktuk is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 09:19 PM #4
cahilc cahilc is offline
cahilc is on a distinguished road
Poking fun at myself... But I'm trying to go the other way and put 15" rims instead of the stock 16" on an '02.
Two reasons better backspacing and wheel weight.
How much additional unsprung wheel weight are you picking up bumping up to a 17"? Just curious.
Yes it's a "truck" but most folks don't realize the additional weight.
Cheers!
2002 Sport Edition (Big Red) 2wd auto, 235k
cahilc is offline   Reply With QuoteReply With Quote
Old 02-21-2020, 01:28 PM #5
Real Name: Blair
Real Name: Blair
Cheers!
From what I read in another thread after refining my Search technique (sry for this super-redundant post), barely any weight at all. I should have mentioned that I was concerned about the 8" wheel width. The 17" wheels I'm considering fit on a 3rd Gen but the thing was all jacked up with a body and suspension lift. I guess I'm wondering about 8" width on a stock 2000 LTD. I guess i can just try it but if it doesn't work I'll have to make another trip to the tire man...
Old 02-21-2020, 02:58 PM #6
Fishwerks's Avatar
Fishwerks Fishwerks is offline
Real Name: Chris
Fishwerks will become famous soon enough Fishwerks will become famous soon enough
Fishwerks's Avatar
Real Name: Chris
Do you know the backspacing of the 17" wheels?
Fishwerks' Photo/Build Thread 2000 SR5 l White on White l 35s l Supercharged
2010 Trail Edition l Salsa Red Pearl l Stock
Instagram
Fishwerks is offline   Reply With QuoteReply With Quote
Old 02-21-2020, 03:10 PM #7
Real Name: Blair
Real Name: Blair
4.5" Backspacing
0 Offset
They are American Racing Baja wheels and the AM online Chatter said they will fit fine with a normal tire like a 265 70
Old 02-22-2020, 12:53 PM #8
For simple comparison looked at Goodyear Trail Runner.
265/70/16 weight is 36lbs.
265/70/17 weight is 47lbs
11lbs difference per tire.
On my '96 running FJ60 chrome steel rims 15" with backspacing of 3.5.
Love the extra 1" on each side. Handles like a completely different truck.
Considering how to get 3.5" backspacing on my' 02 @ 16".
Might simply swap tire sets.
The tire size is 235 vs 265.
The difference between vehicles handling from 3.5" backspace and 4.5" backspace is nothing short of dramatic for me. YRMV.
Old 02-22-2020, 03:39 PM #9
suthernman258 suthernman258 is offline
suthernman258 is on a distinguished road
Tires
What is the best AT tire for 2wd and mild wheeling dirt roads and such? 265/70/16 is what I have. Stock everything so far.
suthernman258 is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 10:24 PM #10
Fishwerks's Avatar
Real Name: Chris
Fishwerks's Avatar
Real Name: Chris
4.5" Backspacing
0 Offset
Some trucks are different but yeah you should be okay with a 265/70/17. The 8" width shouldn't make a difference. The backspacing is slightly lower than stock, but I'd just put them on and trim if necessary.
Instagram
fit , set , unlifted , wells , wheels
2000 on 24" wheels...WARNING FUGLY! dgoll75 3rd gen T4Rs 24 05-21-2014 09:08 PM
Unlifted 2wd 3rd gens with bigger tires..? chainring 3rd gen T4Rs 4 07-08-2012 11:32 PM
Tundra/sequoia split 5 spoke wheels on 2wd (or unlifted) 4runner? chainring 3rd gen T4Rs 7 07-30-2011 12:15 AM
2000 Limited W/Rear Locker and 18" Limited Wheels 4Runnin4 Classifieds - buy & sell (no commercial ads please) 6 03-04-2009 04:55 PM
16" Limited wheels and tires off 2000 4Runnin4 Classifieds - buy & sell (no commercial ads please) 3 01-31-2009 03:21 PM
