02-20-2020, 11:20 AM
#1
Member
Member
Full Synthetic oil,on a high-ish mileage Gen 3?
Used to be that full synthetic oil was considered unwise in high mileage older motors as it was likely to cause oil leaks. I have read recently that modern full synthetic oils are less likely to do this. My T4R has 225k miles on it, a couple slow leaks, mostly or completely from the valve covers, it is less since I torqued the bolts down.
Would like to use Rotella full synthetic, what do people think? Will I leak more oil or the same?
02-20-2020, 11:30 AM
#2
Elite Member
Real Name: Tim
Elite Member
Real Name: Tim
Why not give it a try and see what happens? Nobody is going to be able to give you a concrete answer on whether or not any existing oil leaks will become worse and whether or not any new leaks will pop up when you switch to full synthetic. The worst case is you switch back to conventional if it doesn't work out.
If I were you, I'd go ahead and perform the valve cover gasket job. Unless you pulled off your plenums, you weren't able to get to all the valve cover gasket bolts so you only tightened some of them and not all of them.
__________________
"My old man is a television repairman, he's got this ultimate set of tools. I can fix it!"
02-20-2020, 12:01 PM
#3
Member
Real Name: Keith
Member
Real Name: Keith
I don't see any advantage running synthetic on my type of use. Frequent highway heavy use. I run conventional Castrol GTX 10-30. About 7-8K between changes at running about 1K per week. I have 330K on my motor (387K chassis) and it uses about 1 quart every 4K miles.
I bought a valve cover set but never had time to put it in. So I tweaked all the bolts I could get at, pushing aside the covers and was able to stop the leaking. I didn't torque to spec (they loosen anyway), just tightened them to what felt right, been over a year and 50K and no leaking since.
__________________
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
02-20-2020, 02:41 PM
#4
Elite Member
Elite Member
Quote:
If you have a leak, it is likely to leak more. Why not fix the leaks?
Otherwise, I switched to Rotella T6 a few years back around 250 or 260k miles and am over 290k with no problems or leaks (valve cover gaskets replaced in that time period though). No noticeable oil burned per 5k oil change interval.
-Charlie
__________________
'99 4Runner SR5 Auto - 4WD swapped
'89 Camry Alltrac LE 3S-GTE 5spd
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Previous: '88 Camry Alltrac LE 3S-GE BEAMS, 90 Camry 3S-GTE, 90 Camry DX, '03 WRX wagon, '08 Outback XT
02-20-2020, 03:45 PM
#5
Senior Member
Senior Member
I was using syn-blend on the 4R and 2000 LC until 210K and 232K miles respectively, and then switched to full synthetic Castrol oil. No leaks so far. The 4R is at 215K and LC is at 237K.
If you are replacing the valve cover gaskets, use OEM and apply a small film of Toyota FIPG to the bottom surface on the head.
02-20-2020, 04:07 PM
#6
Senior Member
Senior Member
I've always used amsoil synthetic, even in my older ones approaching 400,000. If there is a leak, it's 'cause you need to replace a seal as Charlie said, not because of the oil.
I second Nissanh, non toyota seals will give you the opportunity to replace them twice.
__________________
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906/Toyota OEM rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
02-20-2020, 04:34 PM
#7
Member
Location: Southern California (please don't hold it against me)
Real Name: michael
Member
Real Name: michael
If you do the valve covers don't for get all the half moons
02-20-2020, 05:01 PM
#8
Member
Member
Do the valve cover job. It’s very easy, Once you do your research. Then if you get stuck at some point there is a video or instructions online somewhere on how to get past the obstacle. Haven’t lost any oil since doing mine and I’m using mobile 1 synthetic.
2001 SR5 4x4 Premium
2017 SR5 4x4 Premium
__________________
17 SR5
02-20-2020, 05:11 PM
#9
Junior Member
Junior Member
I like conventional oil in my old rig. The pros of this in my opinion is that I get to get a thorough look at my truck every 3-5k miles. With synthetic you may go almost a year before having to change the oil. Just my 2 cents. Also I think the leaks will exacerbate with synthetic.
02-20-2020, 05:15 PM
#10
Member
Member
oil is 100% personal preference. I see the value of synthetic, others obviously don't.
Your leaks aren't going to go away by switching to synthetic, they May get worse but I doubt it if they actually are valve cover related. Fix the leaks, switch your oil (if you're so inclined), nothing bad will happen. If you find something about the new oil you don't like, drain it and try something different. It's not like running oil for a change cycle is going to be irreversible.
__________________
'99 Limited 4x4, Millenium Silver ~ Maintenance Thread
02-20-2020, 07:30 PM
#11
Elite Member
Elite Member
I bought 2 saturns with over 140,000 miles plus a 96 4Runner with 220,000, a 97 4Runner with 120,000 and switched them all over to either Rotella T6 or T5 or Pennzoil platinum or ultra and the leaks never got worse.
To me the leaks going to synthetics are a wives tale. I’ve never experienced it.
02-21-2020, 12:06 PM
#12
Member
Member
This! Exactly what I did/do
02-21-2020, 04:29 PM
#13
Member
Member
I appreciate all the posts but no one really answered the question about whether modern fill synthetic oils tend to leak less.
It is my understanding that once a synthetic (or any) oil has found a way out, changing back will will not stop the new seepage, hence the advice against changing to full synthetic oil late in a vehicles life that has only had dino oil.
I am also not about to try to cure the leaks in this vehicle, it not that brisk but also likely not from just the valve cover gaskets. But if they got worse with a
fully synthetic oil I would be pissed. And seitching back to my current oil, from many reports, would not return to my current leak rate.
02-21-2020, 04:41 PM
#14
Member
Member
If you have a leak, it is Possible for that leak to get worse with a change of oil. Doesn't matter if you change brands but stay dino, or change from dino to synthetic.
Having a "minor" leak that's minor because of all the sludge on the inside isn't exactly more desirable than having a bigger leak. Clearly, neither are ideal. Take your chances or don't, but there's no guarantee that the next time you change the oil you won't have worse leaks.
As for the idea that All leaks get worse with a switch to synthetic, that's false. It's 100% dependent on why and where it's leaking. A cracked and worn valve cover gasket is going to leak regardless of the oil and it's not going to leak More just because that oil is now synthetic.
__________________
02-21-2020, 05:34 PM
#15
Elite Member
Elite Member
A men.
It’s a wives tale.
Fix the leak and it will go away. Synthetic oil has an inherently lower pour point than conventional oil does so it’s thinner. Just that, in and of itself will cause the leak that is already there to flow more.
I hate google for making irrelevant things relevant because of all the people that looked at it. I also dislike all the armchair chemical engineers on Bob Is The Oil Guy website.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
