Old 02-20-2020, 05:40 PM #1
nbach218 nbach218 is offline
nbach218 is on a distinguished road
Squeal at 3mph
Hey guys,
First official thread here. Need some help in diagnosing a squeal on my runner. It won’t happen in neutral on idle rev. Just in drive at about 2500-3000 rpms. I’ve replaced all belts in the past year. New timing belt/ pulleys and water pump last month. The alternator was replaced 2 years ago but is a Chinese aftermarket one but it seems to be working fine. I’m having trouble diagnosing this because I can’t get the noise to happen when the car is parked while running. It is a squeal noise and it sounds like a belt. Doesn’t matter if ac or defrost is on or off. All belts are tight with 1/2” deflection. Happens at about 35 mph whether I’m on the gas or off. Any ideas would be greatly appreciated!!
nbach218 is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 08:57 PM #2
Ricktuk Ricktuk is offline
Real Name: Rick Tuk
Ricktuk is on a distinguished road
Real Name: Rick Tuk
If you are saying the squeal only happens while moving you need to be looking at suspension.
common problems
check rear brakes. see if there is any oil from a seal evident.
grease the universals.
Put Front end up and check the ball joints.
Check front bearings and brakes.
Just keep going through process of elimination.
Ricktuk is offline   Reply With QuoteReply With Quote
Old 02-21-2020, 11:02 PM #3
Thank you I will check all these things tomorrow! It almost sounds like a break squeaker, but I replaced front brakes last may which was about 10,000 miles ago.
Old 02-22-2020, 03:45 PM #4
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
Belts will loose after putting them in when they are NEW sometimes they need adjustment. Check for looseness. If you can put your foot on the break put it in drive and increase the throttle you may be able to ID the one giving you trouble if you have some one help you. If you can do it then take some brake clean or some windex spray it on each belt until the bad one goes quiet.
"Careful where you Stand"
You could take off each belt except for the power steering and drive it a short way with out causing any problems to isolate which belt is giving you trouble. Also you can hand spin each pulley to feel for drag also check the idler pull for the a/c as these can get rough.
plcfcng is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 04:19 PM #5
seirunner seirunner is offline
seirunner is on a distinguished road
check drive shaft / u joints
seirunner is offline   Reply With QuoteReply With Quote
belt , i’m , noise , replaced , squeal
Squeal when accelerating Shadow3 3rd gen T4Rs 16 07-14-2019 12:24 PM
3rd Gen Start Up Squeal TanRunnerT4R 3rd gen T4Rs 9 05-10-2017 05:10 PM
drivetrain squeal ultimatt 3rd gen T4Rs 1 12-05-2016 05:18 PM
squeal at down shift shawski Classic T4Rs 12 04-08-2015 11:29 AM
Pulley or Fan Squeal bryancos Maintenance/Detailing 4 03-23-2005 02:23 PM
