Old 02-20-2020, 06:16 PM #1
Ricktuk Ricktuk is offline
Real Name: Rick Tuk
Ricktuk is on a distinguished road
Real Name: Rick Tuk
Ignition lock cylinder workaround in a limited
Hello all. getting back to doing some work on my daughters 4 runner. Having a problem with the ignition lock cylinder sticking. In the drivers door lock I removed a couple of the wafers, not as safe but works. I see several people have done this with ignition cylinders. difference is the Limited has a transponder key. From what I understand the transponder works from the ring around the cylinder. Would I be screwing things up to remove any damaged wafers . Thanks for any wisdom
Ricktuk is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 08:14 PM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Different aspects, they don't really have anything to do with one another. Remove wafers all you'd like, it won't impact the immobilizer system.
Brian. is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 08:59 PM #3
Real Name: Rick Tuk
Real Name: Rick Tuk
Thanks
Thought that was the case but just thought I would check.
Old 02-20-2020, 10:22 PM #4
Inspectorbryan Inspectorbryan is offline
Inspectorbryan is on a distinguished road
When you say sticking, do you mean the key will not turn to the lock position for removal?
Inspectorbryan is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 12:44 AM #5
watersna watersna is offline
watersna is on a distinguished road
Had this happen in my 4runner with the key that came when I bought it. I got by for a while just shoving the key from my dad's old highander into the keyway and wiggling. After that the worn key would work fine. Now I use a third party transponder key cut at the hardware store and it doesn't give me trouble. If you have any other keys around I'd make sure the problem is with the cylinder and not the key before pulling any wafers.
watersna is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 01:15 PM #6
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
You may want to consider having a new key cut from a key tag if you have one (most are lost and gone they are a tiny silver tag when the car is first sold) A dealership can do this I don't know if a locksmith that deals with Cars can do it at any better of a price. Speaking with this type of Locksmith is who I would talk with first.
plcfcng is offline   Reply With QuoteReply With Quote
cylinder , ignition , lock , transponder , wafers
Ignition Lock Cylinder Housing Question Kauban 3rd gen T4Rs 34 05-19-2023 04:59 PM
New '89 (early) ignition lock cylinder Armair1 Classic T4Rs 2 09-22-2019 06:57 PM
04 Ignition lock cylinder replacement help Skiian 4th Gen T4Rs 5 10-05-2018 11:43 PM
New ignition lock cylinder - won't engage ignition - 1996 base CanadaEh 3rd gen T4Rs 2 07-26-2016 03:18 PM
Ignition Key Cylinder jacktahoe 3rd gen T4Rs 0 12-31-2011 09:26 AM
