Old 09-22-2021, 07:56 AM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Can Hella 450/550 handle 100 watt bulbs?
For the most part I am using the wiring kit that came with the driving lights. The only wiring that didn't come with the kit was the low voltage trigger wire sent directly to the switch and relay. I also individually grounded the lights using 14 AWG, that is good for 15 amps (but that is being conservative).
Everything is protected by either a 15 amp fuse or a 2 amp fuse on the switch side. Anyone know if I'll melt the wires using 100 watt bulbs?
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 09-22-2021, 09:25 AM #2
100w bulbs will pull around 10 amps. 100w divided by 14v equals 7.14a per bulb.
Old 09-22-2021, 03:27 PM #3
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
My mistake, I mean 130 watt
Old 09-22-2021, 05:35 PM #4
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I'm not familiar with the Hella kit. Is it to replace the bulbs in the headlamps or are they external? I run 100W Hella bulbs in the headlamps using a relay that feeds off the battery and is activated by the stalk switch. I would not run 130W bulbs as the 100W get very hot if on for a long time at low speeds. If they are external, 130W won't hurt anything that's permanent but just make sure your fuse is smaller than the failing point of the wires. If there's no fuse... you should remove the kit and add one.
326WHP 347TQ
Old 09-22-2021, 09:04 PM #5
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
The lights wiring is external from the wiring harness, and I added them to supplement the weak halogens.
They are mounted on the front bumper. The wiring I added isn't the weak link so the fuse will blow before it does. The housing of the lamps are a lot like sealed beams in size and shape, and they have glass lens.
Old 09-23-2021, 11:58 AM #6
130w/14v=9.28a per bulb. If your only using 1 feed circuit to feed power you need wiring and switches and relays that at minimum can handle 30a.
Old 09-23-2021, 02:11 PM #7
Real Name: Jerod
Real Name: Jerod
Gotcha, that helps. Have you tried running it with 100W bulbs first? I didn't jump from 60W to 100W all at once, I stepped it up incrementally until there was enough light output that I felt was safe for my driving. You might find that 100W is more than enough when combined with the stock lights. Getting a fresh set of TYC 99-02 headlight housings goes a long way as well.
I can't comment on whether the 130W will cause the wiring to fail or not, that's outside of my knowledge. If you know 100W will work just fine within safe limits, that's where I would start.
326WHP 347TQ
Old 09-23-2021, 02:43 PM #8
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I might leave in the bulbs that came with the lights. I'm still trying to figure out a way to keep them from moving around on my janky brackets. They seem plenty bright when they are properly aimed. If I end up using those bulbs I'll share my results
amp , fuse , kit , lights , wiring
Battery to handle Winch & ~1000 watt stereo tyr0981 3rd gen T4Rs 22 01-28-2014 09:49 PM
Hella H3 85 watt? ultimatt 3rd gen T4Rs 3 10-04-2011 01:16 PM
Hella 500 130 Watt bulb??? A10MileHusker General Discussions 3 05-11-2010 12:58 PM
Anyone have issues with IPF lights and 100 watt bulbs? Magnum 3rd gen T4Rs 4 11-02-2009 04:28 PM
80 watt 9006 bulbs? <<<< Engines / Suspension / Wheels / Tires / Audio / Accessories 6 06-14-2007 12:13 PM
