02-23-2020, 11:03 PM
Cruise Control messing with my SGI-5 speedo calibrator
So, some how I actually successfully wired in my Dakota digital SGI-5 and was able to calibrate the system so I could pop my new wheels on!
But... I now have an issue where I cannot use cruise control as when I do the speedometer will randomly jump down 5 mph or so causing the engine and transmission to think they need to vrooooom! If I run without cruise control, this never happens.
I grounded the SGI-5 to the frame vs the ABS harness... Was this perhaps a mistake?
Other random electrical things that I've had before this install are:
- Door lock button rarely works, fob works.
- Light around key cylinder now rarely works
- I always get shocked lightly when I exit the truck now. Like static but it's very apparent and always happens.
Any relation? Ideas?
Also...the new wheels!
02-24-2020, 04:03 PM
I have the SGI-5 too. I get the little blips on the speedo - in my case, only when going up or down through 55mph. I have a feeling it is the SGI-5, not any of the wiring.
So, I'd say your other issues are unrelated.
- Door locks - check if the passenger door button works. You may have bad wiring in the driver'd door harness.
- Key cylinder light - that's a odd one - but the only light in the truck controlled by the integration relay (either bad bulb, wiring, or flaky integration relay)
- Its winter, and might just be dry where you are. Before you start getting out of your seat, touch and keep your hand on the door latch loop on the b-pillar as you get out. You'll never get shocked that way. If you can stand the smell, rubbing a dryer sheet on the seat cloth will work too.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
02-24-2020, 04:11 PM
Charlie - would a throttle cable adjustment affect this cruise behavior? I know my stock setup was less jumpy when I tightened the cable up to spec.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
02-24-2020, 06:23 PM
Seems like that would only affect how it applies the throttle when you set it or when re-applying throttle after a coasting situation...
You can make it totally smooth with some careful application of the throttle manually though.
I think the only suggestion for the original poster is to avoid those speeds where the SGI-5 has glitches when using cruise control... (and yes, I was disappointed when I saw the glitches on mine - but not enough to search for another solution!)
02-24-2020, 06:45 PM
I only offered as mine would have a lag and over-throttle response before the throttle would catch up with the controller's demand. The lag was minimised with adjustment.
_________
02-24-2020, 07:27 PM
Hey all thanks for the replies.
So it isn't a specific speed, I tried CC at 35/40/45/50/55/60/65/70 and random speeds like 53 and such. the little blip only occurs when cruise control is locked. When I stopped testing it today and turned it off I never saw the blips again. To be clear, the speedometer will rapidly drop what seems to be 3-5 mph and I believe the drivetrain takes this as "going up hill, need more power" so she shifts. This is all in a manner of 2-3 seconds. Like "blip, vroom!".
The reason I was asking about the grounding to the harness is that I wasn't sure if maybe there was some kind of ground loop or something. I know generally you grab everything to other friend, but I did not know if maybe with these trucks if there was some special cases where you don't.
Also, thanks for the replies about the other minor issues, I was just concerned about whether or not I might have some kind of underlying electrical issue that could be affecting everything...
02-24-2020, 07:29 PM
Also, for a anyone with a SGI-5 can you post a photograph of your wiring? Curious if I did it right...haha.
Also, what mode are you guys using? I knew it has like seven or eight modes or something like that. By default it's on mode 1.
02-25-2020, 02:31 PM
Zoom in:
I don't remember the modes or anything at this point...
02-25-2020, 02:48 PM
Zoom in:
This is actually the photo that helped me originally! Haha. You grounded it to the harness correct?
02-25-2020, 03:16 PM
Yeah. I don't expect ground loops to be an issue for this... but who knows?
You are using output 2, right?
02-25-2020, 03:52 PM
Yes output two. I also would think ground loops are an issue on a vehicle...but maybe there is a reason there is a ground cable in the harness. I'll swap it and report back after testing.
02-26-2020, 12:26 PM
Okay so it looks like I am using the incorrect mode. Mode 2 is the default, or HH and apparently we need to use mode 2 which is LL. I will try to switch this during lunch and report back.
02-27-2020, 10:18 AM
Well, it actually is already set up on LL. So at this point if changing the grounding does not fix it, I'm officially out of ideas
