Old 02-25-2020, 12:12 PM #1
NEKExplorer's Avatar
NEKExplorer NEKExplorer is offline
NEKExplorer is on a distinguished road
Part Number/Size Needed Please - Bolts that fasten Transmission to Engine Block
I picked up what I hope is a nice 5VZ-FE from a junkyard yesterday and brought it home on a trailer. I would like to mount it on an engine stand to off some of the stuff they left on it and to replace a few things before I hand it over to be installed by a pro, but the yard did not leave any of the bolts for fastening the tranny to the block (and I wouldn't expect them to). I need the bolts to fasten it to the engine stand.
Anyway, does anybody know the part number for these bolts? I would like to order them directly from Toyota rather than try and figure out the right size and thread pitch and risk damaging threads.
Thanks for any help.
"If the American people ever allow private banks to control the issue of their currency, first by inflation, then by deflation, the banks and corporations that will grow up around them will deprive the people of all property until their children wake up homeless on the continent their Fathers conquered...I believe that banking institutions are more dangerous to our liberties than standing armies... The issuing power should be taken from the banks and restored to the people, to whom it properly belongs."
NEKExplorer is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 02:22 PM #2
HiLife HiLife is offline
You'll need 3 bolts each per part number
90119-12267
90119-12005
I don't know the bolt diameters and thread pitch.
Maybe someone else can chime in with these. That way you could pick these up at the hardware store.
Old 02-26-2020, 12:21 AM #3
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
90119-12267
90119-12005
Those 12s tell you it is M12. Works for washers and nuts, too.
Toyota only uses one pitch for each diameter:
6 mm diameter - 1 mm pitch (iso course) - requires 10 mm wrench to fit head / nut
8 mm diameter - 1.25 mm pitch (iso course) - requires 12 mm wrench to fit head / nut
10 mm diameter - 1.25 mm pitch (iso fine) - requires 14 mm wrench to fit head / nut
12 mm diameter - 1.25 mm pitch (iso other) - requires 17 mm wrench to fit head / nut
14 mm diameter - 1.5 mm pitch (iso fine) - requires 19 mm wrench to fit head / nut
16 mm diameter - 1.5 mm pitch (iso fine) - requires 22 mm wrench to fit head / nut
So M12x1.25.
Unfortunately, length is not so easy.
My Backyard Frame Swap
Old 02-26-2020, 12:34 AM #4
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
12x1.25 factory length depends on transmission. But if. You're just using them to install on an engine stand measure and get the best length for the job. Some factory ones are too long, some are too short.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 11:22 AM #5
Awesome everybody, thanks very much for the info. I can't wait to start stripping stuff off this engine, clean it up and do a couple of jobs on my own before I hand it over to a pro for installation.
Old 02-26-2020, 01:25 PM #6
JROTN JROTN is offline
JROTN is on a distinguished road
Hey I may have some bolts that came out of my 02' part out when I pulled the trans.
LMK if you still need them.
JROTN
JROTN is offline   Reply With QuoteReply With Quote
Old 03-01-2020, 09:25 AM #7
So the bolt holes/faceplate on my engine stand will take up 2 1/16 inches or about 54mm of bolt. I am thinking that if I add 50-54mm to whatever the length of the OEM bolt is and buy a 12x1.25 at that length. Anybody know the length of the OEM bolts?
Should I buy grade 8 bolts to make sure the bolts can take the load of the engine? There are only four on my stand. Specs on the motor says it ways 425lbs.
Thanks again
Old 03-01-2020, 09:26 AM #8
any chance you could tell me how long they are?
Old 03-01-2020, 12:17 PM #9
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
it depends on the engine stand. the ones I used were from home depot and they were
M12x1.25x90mm
I have cheapo harbor freight
you need longer/shorter ones depending on your engine stand mount.
I actually made an engine stand out of 2x12's and it almost works better than anything else I have used. a standard sized furniture dolly fitts perfect under it so you can roll the engine around lemon squeeze. unless you need to flip the egine over? the wooden one works better IMO. can leave the flex plate on the egine with the wooden one, can't on the engine stand.
Old 03-11-2020, 07:41 PM #10
Bolts
Hey I just saw this did you get bolts or find out how long they are?
Old 03-12-2020, 12:08 AM #11
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
I bought the grade 8, 12x1.25x100mm for my engine stand and 150mm to make alignment dowels for install.
I bought the grade 8 cause that’s the only bolts my local hardware store had in 1.25 pitch. I bought the 150mm cause they were the shortest with a section of smooth shank.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
block , bolts , engine , part , stand
Part number needed: valve cover bolts and oil cap O ring sakoluvr 3rd gen T4Rs 9 03-20-2018 02:18 PM
Transmission to engine block bolts eurasiaoverland 3rd gen T4Rs 0 04-25-2016 02:10 PM
Hvac part number needed Utopia 4th Gen T4Rs 2 03-22-2016 03:32 PM
TB air hose size and part number stoney 3rd gen T4Rs 0 09-05-2014 01:10 PM
Part number needed! Please help! StreetKill831 3rd gen T4Rs 2 02-09-2013 01:01 PM
