Old 02-26-2020, 09:04 AM #1
Ghostrider Ghostrider is offline
Ghostrider will become famous soon enough
Power steering - drain refill?
Pretty sure mine hasn't been done in years. I did not find any howto's with a search. Is it as simple as remove/replace fluid? On my old Jeep you just used a siphon and added new fluid and cycled it. Repeat the process 3-4 times and you had 90% of the old fluid out. Will that work on a 3rd gen or is it a lot more complicated?
Ghostrider is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 09:06 AM #2
drey6's Avatar
drey6 drey6 is offline
drey6 is on a distinguished road
drey6's Avatar
YouTube
drey6 is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 10:13 AM #3
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
That'll work just fine but there are some full drain/fill methods out there.
Too much trouble IMO, just do few siphon/fill/wheel crank cycles and then do a siphon/fill with every oil change from here on out.
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 10:24 AM #4
drey6's Avatar
drey6's Avatar
YouTube
Or a quicker refresh. ^
Old 02-26-2020, 12:05 PM #5
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Both the videos linked are videos @infamousRNR and I have made. If your fluid hasn't been renewed that often, I'd bet your reservoir screen is clogged up pretty good. If it were me, I'd go ahead and do the full flush, pull the reservoir, and clean out the screen as good as I could with brake cleaner. Power steering fluid is one of those fluids that people forget to renew like brake fluid and the chances your screen is mostly clogged is pretty high.
If you go for the full flush and reservoir cleaning, it has been reported that you don't need to run the pump to effectively move the fluid through the system. All you have to do is have the front wheels off the ground, turn the wheels back and forth a couple times until the level in the reservoir drops, refill the reservoir and repeat until the fluid is coming out clean into your catch container. If the fluid isn't moving through the system as people have reported to us with the engine off, you can always do what we did in the video with the engine running.
I recommend you buy the o-ring that seals the reservoir to the pump because it would suck to get everything back together and then find you have a leak.
Good luck!
Old 02-26-2020, 12:10 PM #6
drey6's Avatar
drey6's Avatar
What he said^ Power steering - drain refill? (sorry, newer to the site- would have tagged you guys but didn’t know the user names off the top of my head)
Old 02-26-2020, 12:13 PM #7
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
No worries. Thanks for linking the videos.
Old 02-26-2020, 12:16 PM #8
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
yep...have the seal handy and replace, not much money. Beats putting it back together and having a leak
Old 02-27-2020, 01:57 AM #9
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
I did this last time on my '97 and it worked well. Much nicer than starting the engine and having the ATF pump out faster than you can pour it in.
Good luck!
Another excellent piece of advice.
pluton is offline   Reply With QuoteReply With Quote
added , cycled , fluid , power , siphon
Looking for DIY 1GRFE Tranny Drain and Refill Stunna1019 4th Gen T4Rs 4 05-08-2018 08:35 PM
trans fluid drain and refill cmills 5th gen T4Rs 54 03-10-2018 11:39 PM
My plan for transmission drain and refill kiana 3rd gen T4Rs 6 11-15-2016 01:02 PM
Help Need - Coolant refill, drain or flush Lyric 4th Gen T4Rs 24 07-16-2013 10:14 PM
how to drain and refill sealed transmission? schan1w Maintenance/Detailing 15 01-30-2009 05:04 PM
