Originally Posted by spartacus
that link is for a 4th gen. 3rd gen are different and the rubber does not simply slide out. at least not on a stock 2000 rear wiper...I know. maybe other 3rd gen years or if someone has put on an aftermarket rear blade.
and those screws can be a pain in the arse. I had to take my arm off, get a small correct fitting head ( 1/4 drive) and using adapters on my hand powered manual impact to get them out. I did debate taking my Dremel and grinding the screw heads to have flat spots so I could grab with a vice grip but my impact worked.
For those that don't know, the manual impacts are the ones you smack with a hammer...no batteries .
there is a thread someplace on this forum that talks about aftermarket rear blades and the replaceable rubber insert.
