Old 03-08-2020, 10:58 AM #16
Middlefingergod Middlefingergod is offline
Real Name: Bean
Middlefingergod is on a distinguished road
Real Name: Bean
I didnt hear any squealing noise like in would think a bearing or pulley would make
Middlefingergod is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 08:52 AM #17
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
Originally Posted by Silver.T4R View Post
Been a busy week but finally had the chance to check the valves using the heater hose yesterday but didn't notice any unusually loud tick from the valves and none of the vacuum lines near the charcoal canister were loose. If it is the flexplate would the sound be noticeable only on cold starts? Also, where is the flexplate located at?
@VernySanders It seems to be coming from the power steering/ A/C condenser area, is there any way to determine whether or not the pulleys are bad?
Thanks for all the suggestions guys
Only way I know to check the bearings would be to take your belts off and give the pulleys a spin. If it turns over rough or makes a bit of a noise that's your culprit. Make sure you spin the bearing all the way
The dunes got boring because I couldn't jump. I'm not the type to enjoy someone else's vehicle. So i'm in the process of making making the dunes no longer boring. I guess that involves jumping.... A lot.
VernySanders is offline   Reply With QuoteReply With Quote
alternator , bearing , find , noises , sound
Water pump play. How much is too much? underscorepatrick 4th Gen T4Rs 8 09-30-2019 09:27 PM
Slight water leak.. water pump or??? LargeOrangeFont 4th Gen T4Rs 6 08-26-2019 06:52 AM
Leak from water inlet/water pump joint - V8 GLP 4th Gen T4Rs 5 01-12-2017 10:52 PM
Chirping sound after Timing belt/water pump/3 drive belts service NoVA_T4R 3rd gen T4Rs 2 06-07-2016 02:02 AM
Help! New timing belt, water pump, and spark plugs = higher water temps??? vthokie 3rd gen T4Rs 15 05-16-2011 10:59 PM
