Old 02-29-2020, 07:09 PM #1
Brandt Brandt is offline
Real Name: Brandt
Brandt is on a distinguished road
Real Name: Brandt
Chasing P0171
I bought a Cali vehicle and immediately replaced the upstream O2 sensor back in October of '18. The truck ran fine until June, then threw another CEL (I forget the code), resulting in the replacement of a couple faulty fuel injectors in August of '19. Immediately after I did that work, I've been getting a P0171.
I've cleaned the MAF and reset the logged code. It returned after a 10 mile drive.
I finally replaced the MAF sensor last week with a Denso unit. Error stayed away for 4 days this time.
I have not replaced any of the hoses. Could this be the issue, and are there any other potential causes for this error?
Thanks in advance for your advice!
Brandt is offline   Reply With QuoteReply With Quote
Old 02-29-2020, 10:48 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
0171 is an air intake leak, usually the rubber components between the maf and intake. I replaced this....
Chasing P0171-new-air-intake-hose-jpg
2001 Limited 4WD - 324K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
Old 03-01-2020, 05:05 PM #3
Real Name: Brandt
Real Name: Brandt
Thanks for the suggestion, jgue467. I'll inspect that hose.
code , error , p0171 , replaced , sensor
Chasing down a oil leak hallj22 3rd gen T4Rs 5 11-18-2018 10:44 PM
Chasing a vibration Tatonka 3rd gen T4Rs 0 03-10-2018 06:25 PM
Chasing The Train Khjphoto Off Topic 0 07-07-2016 02:32 PM
Need Help Chasing a Vibration fdbyrne 4th Gen T4Rs 24 06-04-2015 09:21 PM
Chasing a misfire shamulater 3rd gen T4Rs 10 01-05-2014 12:20 PM
