When my 4R is cold, and I turn the wheel at idle, or just off idle, it feels like it has a stutter.
Belt seems tight, so, could it be the screen in the bottom is clogged? If so, would it hurt anything to use a vacuum to remove the liquid and maybe suck up some of the crud?
99 T4R SR5. OME 906s rear.Stock front springs with 1/4" spacers and Bilstein HDs all around. B&M trans cooler. Deck plate mod and rear diff breather mod. Blacked out bumpers and graphite wheels. Cobra CB in the ashtray. Tundra 199 brake upgrade. Pioneer MVH360BT head unit.
Necessity is the mother of invention.
Recent studies have shown that aggressive therapy combined with owning Toyotas, can be affective in breaking the cycle of Jeep addicition.
Flush out the power steering fluid for a fresh batch. Its an overlooked maintenance point.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
