Old 03-02-2020, 12:07 PM #1
jimmyrecluse jimmyrecluse is offline
jimmyrecluse is on a distinguished road
99 3.4L 4WD Trans Filter Change and Observations
First I've found there are at least two different part numbers for the 3rd gen 4runner trans filter.
I had both 60020 and 60030 on hand. 60020 came out so thats what I put back in.
The pan bolts are 5ftlbs and came out very easy. The gasket was an actual gasket and the pan came off easy, no prying
I was able to pull the dip stick off the pan from underneath without unbolting the mount. Was faster since I dont have a closed on ratchet wrench
I had to disconnect the sway to angle the pan out
Valve body bolts were all torque'd down
I had just changed the fluid a year ago so what came out was still cherry red
There was no sludge at the bottom of my pan and only one magnet had a few metal shavings, otherwise very clean. No sludge anywhere
I used brake cleaner to go over the inside of the pan anyways and let it dry before reassembly
Ended up putting 6 quarts exactly, back in
Overall happy with the progress of the job and the results and findings
jimmyrecluse is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 06:01 PM #2
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Thanks for posting-- I've been very hesitant to crack open my transmission pan on my 2000 4x4 3.4 because I've got the filter ending in 60020 on hand.
Everyone seems to say the 60030 is the right one.
But, glad to hear the 60020 worked on your 4x4
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 08:37 PM #3
itskohler's Avatar
itskohler itskohler is offline
itskohler is on a distinguished road
itskohler's Avatar
Is there any way to tell which filter you need before dropping the pan?
itskohler is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 01:20 AM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Go on a Toyota online parts seller website and look up your year and model 4runner.
Old 03-03-2020, 02:41 PM #5
Give the parts clerk your VIN, can also look it up on Toyota parts store websites - VIN will be definite
I doubt there's harm using the 30 for the 2 hole cars, I wouldnt use the 2 hole filter on a 3 hole trans however
back , easy , gasket , pan , sludge
Observations after removing the hydrocarbon filter LV4R General Discussions 111 03-13-2023 08:06 AM
5spd auto trans filter change or not? 747ifly Maintenance/Detailing 2 12-16-2009 02:18 AM
4th Gen V6 vs V8 Diff fluid change observations GMZ Maintenance/Detailing 2 09-12-2009 01:33 PM
First oil change today, couple of observations - questions G.I.G. 4th Gen T4Rs 11 09-23-2007 10:18 PM
my 1st oil change, and observations while waiting rx900 Gallery 0 12-24-2006 01:52 AM
