Old 03-02-2020, 02:25 PM #1
cooker cooker is offline
cooker is on a distinguished road
rear window washer '96 limited
I just bought this vehicle for $1600.00. The rear window washer is the only thing I can find that doesn't work. Can someone help me on how to troubleshoot, what to look for? Thanks in advance!
cooker is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 06:00 PM #2
4Skinner98 4Skinner98 is offline
4Skinner98 is on a distinguished road
It could be as easy as the nozzle came unplugged from the washer hose. Try using the washer and see whether fluid leaks from the hatch somewhere.
4Skinner98 is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 09:11 AM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Those actually run off your front washer reservoir. The plastic hose runs all the way back. I would see if it came apart like the others have suggested. The tip should be free of dirt and debris as it could be plugged. Do you hear the motor run when you engage the sprayer? As rarely those motors can seize or fuse blown. With damaged wiring.
Old 03-04-2020, 01:06 AM #4
rear washer
I found the leak today. Where the hard plastic hose goes through the inner passenger fender had a hole rubbed through it. I took off the passenger rocker plate and kick plate but the hose doesn't want to move so I can splice the hole. Lots of stuff behind the kickplate and can't really see the grommet into the cabin from the fender well. Got some replacement 1/8" tubing but O'Reilly was out of connectors. Getting the wheel well cover off was a pain and still couldn't get enough slack to splice the hole out of the line. Going to wait for warmer weather and get the correct connectors to try again. I plan on cushioning the line where the hole was worn so it is more protected from vibration wearing another hole. Don't know why Yotya used hard plastic and rubber hose combinations in this line...
rear , troubleshoot , washer , window , work
Rear window washer fluid 4Funnr 5th gen T4Rs 27 06-11-2021 12:11 PM
Rear washer/window issue WU7X 3rd gen T4Rs 6 08-27-2012 08:01 PM
Rear window washer Gryphon Classic T4Rs 5 01-22-2010 11:10 AM
4th gen leaking rear window washer KGB4187 Problems & Warranty Issues 1 06-26-2007 10:28 PM
Rear window washer yota Maintenance/Detailing 1 03-12-2003 02:44 PM
