Originally Posted by T4RE-L505
do you mind circling the area you're talking about with the space with the lower support bolts ?
Sent from my SM-N960U using Tapatalk
Post #11 picture 1 you see how manageld that frame rail is to mine. Below the radiator support has a piece of steel welded in with about a 1/4 gap between it and the support. Frame rail is the boxed frame. The support that runs to the other frame rail should be flush against. That support is where a standard skid plate would bolt to in the front.
This is why i am saying it looks like the frame rail is bent to the left and up.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
