Old 03-13-2020, 08:06 PM #16
T4RE-L505's Avatar
T4RE-L505 T4RE-L505 is offline
T4RE-L505 is on a distinguished road
T4RE-L505's Avatar
Originally Posted by brillo_76 View Post
Your passenger side looks like its bent over and up as there shouldn't be a space between the lower support the bolts for the skid plate go into and the frame.
Granted, tweaking the bumper mounts should get the bumper back on.
I would imagine someone chopped those off to try to bend it back closer to where it should be.
Explains why your parts aren't matching up perfectly though.
do you mind circling the area you're talking about with the space with the lower support bolts ?
Sent from my SM-N960U using Tapatalk
'97 3rd Gen 4Runner Limited Black
T4RE-L505 is offline   Reply With QuoteReply With Quote
Old 03-13-2020, 08:27 PM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Post #11 picture 1 you see how manageld that frame rail is to mine. Below the radiator support has a piece of steel welded in with about a 1/4 gap between it and the support. Frame rail is the boxed frame. The support that runs to the other frame rail should be flush against. That support is where a standard skid plate would bolt to in the front.
This is why i am saying it looks like the frame rail is bent to the left and up.
Old 03-13-2020, 08:29 PM #18
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Full size zoom in the frame rails and compare to yours. You can see the differences.
Old 03-13-2020, 09:36 PM #19
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Thought I posted on this, but don’t see it.
Your passenger frame rail looks to be bent toward the drivers side. The hinge point is probably where the frame rail leaves the main cross member under the front of the engine.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 03-15-2020, 03:16 PM #20
Moosause Moosause is offline
Real Name: Brian R Bergeson
Moosause is on a distinguished road
I tried a few threads and could not find the exact information, if anybody has any links to a thread that talks about this info let me know so I don't waste anybody's time.
I have just purchased a Coastal Offroad Bumper DIY Kit and one of the first things you have to do is mounting a plate to the Frame Rail. The Passenger side Frame Rail is a little tweaked from what seems to have been a minor accident from previous owner and the Bolts I have from the factory recovery hooks and the plate I am trying to mount don't line up with the Frame Rail, are there any suggestions on how to straighten this out? rufus
Also I am pretty positive I am missing bolts from that Frame rail area if anyone knows what the (4) bolts are I would appreciate it.
Do you think it would be a dumb idea to clearance the bolt hole on the plate just to get the bolt to go in straight?
The tension would still hold the plate, I would think.
Moosause is offline   Reply With QuoteReply With Quote
Old 03-15-2020, 08:36 PM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Nothing wrong with just making it work with what is available. That's probably what I would do if I was in that position. Or I replace a section of frame. However, most people are unable to do that. ;)
bolts , frame , mount , plate , rail
Replacing frame rail # 5 kgbagent 4th Gen T4Rs 5 09-19-2017 05:14 PM
99 frame rail corrosion jshark Problems & Warranty Issues 3 07-17-2017 08:51 PM
4th Gen Rear Frame Rail Measurements? BlackWorksInc 4th Gen T4Rs 5 06-05-2017 11:16 AM
Frame Rail Thickness? MStudt 3rd gen T4Rs 8 03-10-2014 08:58 AM
TQ Spec for front bumper to frame rail? LI4runner 5th gen T4Rs 1 08-25-2013 09:03 PM
