Old 03-06-2020, 05:15 PM #1
06LTD 06LTD is offline
06LTD is an unknown quantity at this point
Speedo and tach stopped working
The speedometer and tach stopped working in my 2000 4runner. This has happened twice within the last week or so. The first time i disconnected the battery and it worked for a day or two. The second time it happened the speedo stayed on 45mph but the tach went to 0 while driving. The speedometer stayed at 45 even when the truck was turned off. I disconnected the battery and the speedo needle went to 0 and the tach was working again. Any ideas as to what is causing this?
2000 4runner SR5 4x4 auto
06 LTD V8 black
07 Jeep GC SRT8
03 Cobra
06LTD is offline   Reply With QuoteReply With Quote
Old 03-06-2020, 08:09 PM #2
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light
Real Name: Jerod
Check the speed sensor on the transmission and that the wiring on the sensor is secure.
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
Old 03-07-2020, 12:18 AM #3
kolelt kolelt is offline
kolelt will become famous soon enough
4runners use ABS to monitor speed. OP The speed sensors are your ABS. Each wheel has a sensor going to it. Could be that those are bad, maybe dirty or you have some other issues. Pull them, clean them and try again. I had similar issue. For the life of me I couldnít figure it out. So I installed a Tacoma speed sensor which goes behind the transfer case. And I wired it to my Speedo.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 03-07-2020, 01:16 AM #4
Real Name: Jerod
Real Name: Jerod
My bad, I had been working on a 4Runner lately and the parts diagram showed a speed sensor. That must be only for non-ABS versions, which I'm told are quite rare.
Old 03-07-2020, 10:30 AM #5
brillo_76's Avatar
Real Name: Jon
brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light
brillo_76's Avatar
Real Name: Jon
Mostly if you have any kind of ABS issue the ABS light will let you know. I am curious what exactly is the cause of this. As it sure sounds like the Signal isn't making it to the gauge cluster or the gauge itself is dying.
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
battery , speedo , stayed , tach , working
2005 Tach stopped working Fern 4th Gen T4Rs 10 01-31-2015 01:32 PM
Speedo / Tach non-op Baja 4th Gen T4Rs 6 05-14-2013 12:52 AM
Tach not working correctly? cage1234 4th Gen T4Rs 6 08-19-2009 01:41 AM
Tach and Temperature Gauge not working properly kdanielp3 Problems & Warranty Issues 0 12-31-2008 11:49 AM
speedo and odometer stopped working Paul H. Problems & Warranty Issues 6 06-25-2004 03:54 PM
