Old 03-07-2020, 10:01 AM #1
Pj Benn Pj Benn is offline
Pj Benn is on a distinguished road
Pj Benn's Hawaiian time maintenance and build
Howsit. New 4runner owner from the west side of Oahu. Bought my 1998 Limited 4x4 on new years day. It had 152k miles on the clock. Have been trying to get through all the maintenance and hopefully some upgrades in the future.
previous owner replaced radiator. Also has recently replaced starter, bilstein 5100's, ome 906 rears, front o2 sensor, air filter.
Since I've owned it I replaced the
-oil
-front diff oil
-transfer case oil
-rear diff oil
-rear axle seals
-2 new tires (fronts were cupped bad from unbalance and alignment)
-front brakes
-spark plugs and wires
also added a remote to factory alarm system and replaced the piezo.
Upcoming work
-cv axles (previous owner said binside boots split 3 years ago after lift) *done
-lower ball joints *done
-valve cover gaskets *done
-e locker sensor *wasn’t sensor. Replaced with used elocker
-rear driveshaft check balance/lube
-inner/outer tie rods(?) * done along with new rack
-sway bar bushings
-rear lower control arm bushings
Pj Benn is offline   Reply With QuoteReply With Quote
Old 03-07-2020, 10:18 AM #2
coming up tomorrow
tool list for job
-10mm socket
-19mm socket
-24mm socket
-35mm socket
-otc 6295 front end kit
-1/2in drive breaker bar, torque wrench and impact wrench
-dead blow hammer
-mini sledge
-pry bar
parts list for job
-front diff fill plug washer
-front diff fluid to top off
-reman cv axle
-new lower ball joint
If i forgetting anything or theres anything that will make the job easier please let me know. I'll need to pick it up today because i hope to finish the job before sunrise tomorrow.
Old 03-08-2020, 10:12 AM #3
Half way through and then see this
After paying the premium for Toyota parts and waiting over a month this hurts. Guess I learned the hard way to inspect when picking up or at the very least before installing.
Old 03-08-2020, 10:59 AM #4
Middlefingergod Middlefingergod is offline
Real Name: Bean
Middlefingergod is on a distinguished road
Real Name: Bean
Nice rig and beautiful place to live. I lived on the north shore of Oahu years ago.
Middlefingergod is offline   Reply With QuoteReply With Quote
Old 03-08-2020, 02:12 PM #5
Thanks. North shore is beautiful. Been trying to get out that side more often. Traffic can be terrible on the weekends though.
Old 03-08-2020, 02:25 PM #6
Guess my earlier post was a little dramatic. I thought that bent shield went inside the other side and would interfere with something. It goes outside and after I bent it back seems like seals will still work fine. Hopefully can reboot old cv and it’ll be ok. Not sure how to check if it’s good enough to reboot though
Old one felt really good still. Looked ugly but no tears
Put the new one in anyway. Preventative maintenance
Old 03-09-2020, 12:37 AM #7
RotaryDreamz's Avatar
RotaryDreamz RotaryDreamz is offline
Real Name: Sean
RotaryDreamz will become famous soon enough
Real Name: Sean
Nice rig braddah! Grew up in Waianae. Hakimo rd. Family stay off waianae valley road still. Maybe I see you around next time I visit.
RotaryDreamz is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 03:49 PM #8
shootskden shootskden is offline
shootskden is on a distinguished road
looks clean brah! cherry
shootskden is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 08:48 PM #9
Grew up right around the corner. New neighborhood behind 76 gas station. Grad Waianae 2002. Throw 🤙🏽 if you see me
Mahalo nui!
Old 03-15-2020, 05:59 PM #10
Started carpeting the storage/sleeper previous owner had built
Old 03-16-2020, 09:02 PM #11
Got a little mud on the runner on the way to and from the beach yesterday
Old 03-17-2020, 09:43 PM #12
Got most of the carpet done and installed box with a couple turn buckles. Had to get it done ASAP to clear space in garage in case of shelter in place. Might add some handles for aesthetics. Still gotta do the wings and sleeper part. Deciding if I want to use different hinges and legs for those though
Old 04-21-2020, 05:53 PM #13
Did drivers side lbj this morning. Old one felt fine still.
Old 04-22-2020, 09:35 AM #14
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
The majority of CV axles I've seen from Toyota over the years had that same area folded over & had to use pliers to bend it back to shape. I'm assuming it's from not being very securely packaged during shipping.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 04:35 PM #15
Ah ok I guess I can expect the same when I order the next one. Kinda junk because after the ‘paradise tax’ it comes out to $3xx. Considering buying from the mainland and getting it shipped here instead but not if it might get banged up worse.
front , oil , owner , rear , replaced
Hawaiian Hillbilly on the Cheap 04' SR5 build Hawaiian Hillbilly 4th Gen T4Rs 21 01-07-2017 04:39 AM
Hawaiian Ryan Mild Lift Build hawaiianryan 5th gen T4Rs 10 06-11-2016 02:56 PM
Time for front end maintenance Desertrunner25 3rd gen T4Rs 9 03-01-2016 03:46 PM
Just hit 150k time for some maintenance foxrider56 3rd gen T4Rs 7 03-16-2014 03:44 PM
Hawaiian Wheelin KingJerd Classic T4Rs 1 08-13-2008 01:59 AM
