Old 03-10-2020, 03:19 PM #16
sweet88gt's Avatar
sweet88gt sweet88gt is offline
sweet88gt is on a distinguished road
sweet88gt's Avatar
I first believed it was a fuel pump but I have since figured it either worked or didn't.
I haven't ruled anything out.
1997 3.4 Limited 4x4 197xxx miles
sweet88gt is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 03:44 PM #17
spartacus's Avatar
spartacus is just really nice spartacus is just really nice spartacus is just really nice spartacus is just really nice
spartacus's Avatar
These guys here in CO do a great job. small shop 20 dollars each for total rebuild and testing.
Fuel Injector Specialists - Home - Wheat Ridge, CO
Old 03-10-2020, 03:47 PM #18
brillo_76's Avatar
Real Name: Jon
brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light
brillo_76's Avatar
Real Name: Jon
Fuel pressure at the rail will rule the pump out
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 03-10-2020, 04:12 PM #19
sweet88gt's Avatar
sweet88gt's Avatar
Limited tools is whats holding me back on some of these projects. Looks like the fuel pressure test could be a bit fun.
Old 04-05-2020, 11:09 AM #20
sweet88gt's Avatar
sweet88gt's Avatar
So Im going to bring this back as I have been on and off looking into the issue.
So yesterday I wanted to fix the leaking valve covers. I changed them and all associated items. Checked hoes and such to just give it a once over.
Took it to get gas (on 1/4 tank). Put Seafoam in gas and drove home.
idling in driveway looking for my flashlight to check for any anomalies. It dies with no warning.
I got it started runs ok
But here is the new issue. My code scanner will not read codes now just says error.
Starting back a square one.
Spark plugs few months old. Coil pack checked via ohm. New spark plug wires. Cleaned MAF. New pcv valve. Cleaned throttle body carefully. Newer fuel filter. Seafoam in engine.
Old 04-05-2020, 01:12 PM #21
sweet88gt's Avatar
sweet88gt's Avatar
https://www.youtube.com/watch?v=aAPB...ature=youtu.be
So I took out the fuse for OBD2 checked it and reinstalled. It gave me an error once more but then worked. I noticed while it was communicating I heard a strange noise. The video above explains the noise.
This is the same style noise I have heard once it dies and I pop the hood.
Old 04-05-2020, 01:29 PM #22
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is a jewel in the rough LittleCaesar is a jewel in the rough LittleCaesar is a jewel in the rough
Have you cleaned the IAC?
Grab a long screwdriver or a piece of vacuum hose to pinpoint the location of the noise.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 01:34 PM #23
sweet88gt's Avatar
sweet88gt's Avatar
I have not cleaned the IAC
That noise only pops up sometimes. Kind of sounded like it was coming from under or behind the intake. Maybe injector?
Old 04-05-2020, 01:35 PM #24
HiLife HiLife is offline
HiLife will become famous soon enough HiLife will become famous soon enough
Strange noise indeed.
Could it the starter solenoid making that noise? But then again the ignition needs to be in start unless you have a short.
Old 04-05-2020, 01:39 PM #25
sweet88gt's Avatar
sweet88gt's Avatar
That video was with key on engine off during code scan.
Old 04-05-2020, 01:45 PM #26
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 will become famous soon enough Doc2012 will become famous soon enough
Doc2012's Avatar
My bet is on your TPS/IAC.
Look at my torque spec/service information thread for values.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 01:47 PM #27
sweet88gt's Avatar
sweet88gt's Avatar
https://www.youtube.com/watch?v=bvUVH8kusxk&feature=youtu.be
Here is a video from right after a stall probably a few weeks ago. Notice how the check engine light flickers. It throws no codes before or after a stall.
Just throwing this up here for reference.
Old 04-05-2020, 01:48 PM #28
sweet88gt's Avatar
sweet88gt's Avatar
Since we are stay at home Ill look into that now.
Thanks
Old 04-05-2020, 02:04 PM #29
Yes, check you iac. I had a dirty iac that resulted in stalling in idle. I removed it and cleaned it and my stalling in idle went away but, the ecu never threw a code during the stalling event. I would ohm out the tps and iac to make sure those are in spec.
Old 04-05-2020, 02:09 PM #30
sweet88gt's Avatar
sweet88gt's Avatar
If Im checking the IAC correctly its not within the spec Doc2012 has listed. Ill do the TPS next
Im unsure of the pinout. Actually which pins are which.
check , fuel , issue , light , today
Fitting 295's Lets Talk WEAK_E90 5th gen T4Rs 17 09-10-2019 01:04 PM
Lets talk HIDs patricksheehy 4th Gen T4Rs 2 09-12-2010 05:58 PM
now lets talk capaciters 08medic4x4 Engines / Suspension / Wheels / Tires / Audio / Accessories 11 04-02-2010 01:13 AM
lets talk tires urcnj 4th Gen T4Rs 2 08-27-2008 12:14 PM
Lets talk about colors Falls 4th Gen T4Rs 28 01-03-2007 03:00 PM
