Old 04-05-2020, 08:49 PM #61
19963.4lsr5 has a spectacular aura about 19963.4lsr5 has a spectacular aura about 19963.4lsr5 has a spectacular aura about
Originally Posted by sweet88gt View Post
Will do
Going to try to get it out on the road and test drive tomorrow
Donít be disappointed if it stalls a few times in the beginning of your drive.
Old 04-06-2020, 02:20 PM #62
sweet88gt's Avatar
sweet88gt sweet88gt is offline
sweet88gt is on a distinguished road
sweet88gt's Avatar
https://www.youtube.com/watch?v=aAPB...ature=youtu.be
So I took out the fuse for OBD2 checked it and reinstalled. It gave me an error once more but then worked. I noticed while it was communicating I heard a strange noise. The video above explains the noise.
This is the same style noise I have heard once it dies and I pop the hood.
So this noise has been found to the be the IAC clicking like crazy. Took long 3/8 extension and once it stalled figured that out.
https://www.youtube.com/watch?v=4Ncn...ature=youtu.be
1997 3.4 Limited 4x4 197xxx miles
sweet88gt is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 02:27 PM #63
sweet88gt's Avatar
sweet88gt's Avatar
To add to this I did get it running and it runs about the same with or without the TPS sensor plugged in. Once the noise started I focused in on that and will revisit the TPS after I figure the noise out.
Old 04-06-2020, 06:25 PM #64
sweet88gt's Avatar
sweet88gt's Avatar
So if were going to throw parts at the issue and the IAC and TPS need to be replaced where is the best place to order these items from?
That IAC from Toyota is a pricy part. The TPS not too bad.
I want to be done with this issue and move on to other things.
Anyone got an in for cheap factory parts?
Old 04-06-2020, 06:54 PM #65
Can you go junking and find a used complete throttle body? Craigís list, eBay, FaceBook market place......
Old 04-06-2020, 07:19 PM #66
sweet88gt's Avatar
sweet88gt's Avatar
I have but the units at the yard thats still open is picked over and complete junk.
I would spring the $200 for the IAC if I knew it would fix the problem for sure. I would even get the TPS just because.
Looks like Im gonna have to bite the bullet on this one I suppose.
Old 04-06-2020, 07:37 PM #67
A few members have used the aftermarket IAC with luck.
If you can get a Borg Warner or Napa IAC I would try it over the factory one.
It be nice to stumble upon a complete Throttle Body from a part out.
The one member here that lives in Florida got me rust free power steering lines. Someone here may be able to do the same for you.
Old 04-08-2020, 01:58 PM #68
Reading the outside two pins
.6k ohm at idle and 3.1k ohm at WOT
Old 04-09-2020, 04:54 PM #69
sweet88gt's Avatar
sweet88gt's Avatar
.51 ohm at idle and 2.88 ohm at WOT for the one on the truck
Old 04-09-2020, 05:57 PM #70
That is K ohms, correct?
I have two spare throttle bodyís. I should check that one also.
Old 04-09-2020, 06:19 PM #71
sweet88gt's Avatar
sweet88gt's Avatar
Yes
I ordered a new IAC and TPS. Shipping time is gonna be awhile so Ill wait to update. Im done messing around with it.
Old 04-10-2020, 11:48 AM #72
My other spare TPS is .63k ohm to 2.81k ohm.
Old 04-13-2020, 04:56 PM #73
sweet88gt's Avatar
sweet88gt's Avatar
https://www.youtube.com/watch?v=eNRH...ature=youtu.be
After Toyota IAC and TPS
Start up after parts went very smooth. 30 min run time with no issues. Let sit for 30 min. Restart and within 10 min a stall.
The truck hard start is due to the stall after effects. The truck has been a bit harder to start as of late.
Video is during the after stall restart. The noise Im hearing the loud clicking only happens when the truck is about to stall or after the stall has happened.
Im thinking as someone earlier mentioned that fuel injector ?? As it still posts no codes.
I will now look into a bluetooth app for my iPhone to look monitor fuel pressure and such.
The saga continues.
Old 04-13-2020, 06:51 PM #74
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar has a spectacular aura about LittleCaesar has a spectacular aura about LittleCaesar has a spectacular aura about
That stinks. It sounds like a sticking solenoid to me, but where, and which one, I couldn’t say. Almost like a starter not disengaging.
How is the voltage?
Ever adjusted the valves?
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 07:27 PM #75
sweet88gt's Avatar
sweet88gt's Avatar
How is the voltage?
Never adjusted valves. This thing ran great until one day poof. Since then can't get her dialed in.
Battery good.
check , fuel , issue , light , today
Fitting 295's Lets Talk WEAK_E90 5th gen T4Rs 17 09-10-2019 01:04 PM
Lets talk HIDs patricksheehy 4th Gen T4Rs 2 09-12-2010 05:58 PM
now lets talk capaciters 08medic4x4 Engines / Suspension / Wheels / Tires / Audio / Accessories 11 04-02-2010 01:13 AM
lets talk tires urcnj 4th Gen T4Rs 2 08-27-2008 12:14 PM
Lets talk about colors Falls 4th Gen T4Rs 28 01-03-2007 03:00 PM
