Originally Posted by 19963.4lsr5
It’s still worth knowing what the compression is with your milage.
Stalls at idle on the old CJ were two cylinders running 90psi hot.
Also ohm our your coils and anyone near the upper limit resistance wise replace.
Sadly none of your missfire codes have a ignition coil in common.
What is your MAF and Load reading at idle?
I am going to run it tomorrow and wait till it stalls and pull the plugs to see what is what. In a stall it always smells of fuel which now leads me back to unburnt fuel.
Tunnel vision sometimes gets hard to get away from.
I have ohm tested the coils before but always cold. I will check them out when hot as well. Ill look for the values for both. Ill check the wires again as I changed them due to arcing on one of the coils.
All a matter of process with limited tools.
Fuel pressure and compression will be on the list.
