Old 04-05-2020, 02:19 PM #31
Originally Posted by sweet88gt View Post
https://www.youtube.com/watch?v=aAPB...ature=youtu.be
So I took out the fuse for OBD2 checked it and reinstalled. It gave me an error once more but then worked. I noticed while it was communicating I heard a strange noise. The video above explains the noise.
This is the same style noise I have heard once it dies and I pop the hood.
The video says the engine is running. It could be an exhaust leak at one of the crossover flanges.
The second video could be a bad TPS because of how it only does it when you blip the throttle. The TPS sensor sets up the entire spark and fuel mapping. If it’s bad the ECU is getting bogus load demand info and has to rely on the O2 sensor to correct. A bad TPS can cause stalling too. I’ve done quick IAC cleaning by removing the lower idle bypass air tube and spraying in the hole until clean chunk free TB cleaner is visible coming out the air port in the throttle body throat.
Get a scanner that reads live data. I have a hand held Innova and a Mac Mentor. My Innova is my main go to scanner.
Dash Command is on my iPhone and torque pro is on my cheep tablet.
Old 04-05-2020, 02:20 PM #32
HiLife HiLife is offline
IIRC the center is positive and the left and right pins are what opens and closes the iac valve. As to what left and right pin does what I don't remember.
It's easy to screw up the iac if your cleaning with the throttle body mounted, be careful.
Edit* The center pin is the positive pin.
Old 04-05-2020, 02:30 PM #33
sweet88gt's Avatar
sweet88gt sweet88gt is offline
sweet88gt is on a distinguished road
sweet88gt's Avatar
I have the Innova 3020 which had been working good until the error messages. Then the clicking noises when I was trying to retrieve codes.
1997 3.4 Limited 4x4 197xxx miles
sweet88gt is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 02:31 PM #34
sweet88gt's Avatar
sweet88gt's Avatar
Originally Posted by HiLife View Post
IIRC the center is ground and the left and right pins are what opens and closes the iac valve. As to what left and right pin does what I don't remember.
Going outside now to check it out
I will unmount the throttle body if I think that is an issue
Old 04-05-2020, 03:15 PM #35
Does it read live data?
Old 04-05-2020, 03:18 PM #36
sweet88gt's Avatar
sweet88gt's Avatar
No just a cheap plug in.
Ill look into the bluetooth for Apple products tonight.
Old 04-05-2020, 03:25 PM #37
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Take head to make sure you don’t get those coolant and vacuum hoses mixed up underneath the Tb that attaches to the IAC.
To check the IAC:
https://m.youtube.com/watch?v=agIRNNA-6cs
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 03:29 PM #38
sweet88gt's Avatar
sweet88gt's Avatar
To check the IAC:
Tested the values and I was at 21.x on both terminals. 80 degrees here today in Florida but within spec on the IAC
Old 04-05-2020, 03:31 PM #39
I would get a hand held also.
Old 04-05-2020, 03:34 PM #40
sweet88gt's Avatar
sweet88gt's Avatar
Sorry the cheap plug in I have is a wired handheld.
I want to find a bluetooth option so I can check live values.
Old 04-05-2020, 03:39 PM #41
sweet88gt's Avatar
sweet88gt's Avatar
Before
https://www.toyota-4runner.org/attac...1&d=1586115348
After
https://www.toyota-4runner.org/attac...1&d=1586115512
Lets talk tests-img_2159-jpg  Lets talk tests-img_2160-jpg
Old 04-05-2020, 03:47 PM #42
Your iac doesn't look that bad to begin with. Mines were way worse with carbon. Since you have is off might as well check ohms if you have a meter.
Between center and right and then, center and left should be in the 17-25 ohm range to pass.
Old 04-05-2020, 03:54 PM #43
sweet88gt's Avatar
sweet88gt's Avatar
Tested 21
Old 04-05-2020, 04:40 PM #44
sweet88gt's Avatar
sweet88gt's Avatar
So Im lost or not looking in the right spot. Can anyone tell me which pins from top to bottom of the TPS sensor are ?
I have FSM but it shows a 4 wire setup for a 2002 and I have a 3 wire for my 97.
If anyone wants to spoon feed me the values I will gladly take those as well.
Old 04-05-2020, 04:51 PM #45
That IAC really got clean. I suspect that is the problem but will be curious if that sound comes back.
You will need a handheld vacuum pump along with a dvm to test the TPS. The pumps are usually $20~$35 at the auto parts stores:
HELP NEEDED...checking TPS on 3.4 V6. - YotaTech Forums
check , fuel , issue , light , today
Fitting 295's Lets Talk WEAK_E90 5th gen T4Rs 17 09-10-2019 01:04 PM
Lets talk HIDs patricksheehy 4th Gen T4Rs 2 09-12-2010 05:58 PM
now lets talk capaciters 08medic4x4 Engines / Suspension / Wheels / Tires / Audio / Accessories 11 04-02-2010 01:13 AM
lets talk tires urcnj 4th Gen T4Rs 2 08-27-2008 12:14 PM
Lets talk about colors Falls 4th Gen T4Rs 28 01-03-2007 03:00 PM
