Old 04-05-2020, 05:13 PM #46
sweet88gt's Avatar
sweet88gt sweet88gt is offline
sweet88gt is on a distinguished road
sweet88gt's Avatar
Originally Posted by LittleCaesar View Post
That IAC really got clean. I suspect that is the problem but will be curious if that sound comes back.
You will need a handheld vacuum pump along with a dvm to test the TPS. The pumps are usually $20~$35 at the auto parts stores:
HELP NEEDED...checking TPS on 3.4 V6. - YotaTech Forums
That diagram the TPS has 4 terminals. The one I have has 3 terminals. Am I crazy to say that I haven't found a pinout or diagram for the one I have.
1997 3.4 Limited 4x4 197xxx miles
sweet88gt is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 05:43 PM #47
sweet88gt's Avatar
sweet88gt's Avatar
So after cleaning the IAC and reinstalling everything it now stall even worse. Doesn't surprise me but here is another video. It now will only run for a min and stall.
This now happens everytime I start it up.
https://www.youtube.com/watch?v=2Zls...ature=youtu.be
Old 04-05-2020, 05:46 PM #48
19963.4lsr5 19963.4lsr5 is online now
Lets talk tests
Here is what the drawing shows. Live data is better.
1-3 and 2-3 should equal what 1-2 is. 3 is the wiper and it’s resistance to pin 1 and 2 will change with position.
I have an older 3120 I upgraded with ABS. I love mine. It was worth the 100 dollars I spent on it.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 04-05-2020, 05:49 PM #49
It may need to relearn it’s idle. Let it warm up giving it partial throttle and then slowly back off the throttle. Or give it a some time to relearn. It may take a few drive cycles.
Old 04-05-2020, 05:54 PM #50
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
According to my parts reference the TPS 89452-35020 fits all 5vz 4runners from 8/96-8/2000, until when drive by wire was introduced. How many pins does the TPS connect have?
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 05:56 PM #51
MarkamisPrime's Avatar
MarkamisPrime MarkamisPrime is offline
MarkamisPrime will become famous soon enough MarkamisPrime will become famous soon enough
Unplug the tps. And turn the truck on or have the truck on and then unplug the tps
The truck doesn’t need it to run or idle
But if your tps is bad telling the ecu that your flooring it and your at idle it’s going to flood itself and turn off.
2012 TRD Tacoma wheels
Grey wire mod
Toytec ultimate lift w/super flex rear coils
1.25 spidertrax coming soon
MarkamisPrime is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 05:58 PM #52
sweet88gt's Avatar
sweet88gt's Avatar
It has 3 pins
Old 04-05-2020, 05:59 PM #53
sweet88gt's Avatar
sweet88gt's Avatar
Im going to try to let it run and see what happens first then I will try your idea.
Old 04-05-2020, 06:11 PM #54
Lets talk tests
It’s not an idea
If it is your tps that will tell you if it’s bad or not.
Same logic as having a misfire and swapping coil packs see if the problem follows the coil pack. Then you know that one is bad, save you the trouble of having to ohm things out or back probe.
Same thing happened to my truck
And I did all the same exact things you did
I even went as far as replacing the iac and the maf just cause I had a parts truck.
Not until I look at my live stream data I could see my tps voltage was all over the place. I unplugged it turned the truck on truck was perfect
Swapped the sensor with one off the parts truck it’s been fine for a year now
Grey wire mod
Old 04-05-2020, 06:14 PM #55
My bad. This is a FSM for a 1996 t100 but should be the same for you:
The page is di-166, or 430 in the PDF:
http://htftp.offroadsz.com/marinhake...T100%20FSM.pdf
Old 04-05-2020, 07:41 PM #56
Tomorrow I can ohm our a spare TPS I have if you like.
Old 04-05-2020, 07:59 PM #57
sweet88gt's Avatar
sweet88gt's Avatar
If possible that would help
Thanks
Old 04-05-2020, 08:01 PM #58
sweet88gt's Avatar
sweet88gt's Avatar
It’s not an idea
So I let the truck warm up and it finally learned to idle normally and wouldn't die(for the 5-10min I let it run).
I unplugged the TPS and it stumbled and ran like normal just threw a code.
I plugged it back in and it stumbled and ran the same.
Both items done at idle in driveway.
Old 04-05-2020, 08:10 PM #59
See what happens putting it in gear with foot on the brake. It may need to relearn that also.
Old 04-05-2020, 08:28 PM #60
sweet88gt's Avatar
sweet88gt's Avatar
Will do
Going to try to get it out on the road and test drive tomorrow
check , fuel , issue , light , today
Fitting 295's Lets Talk WEAK_E90 5th gen T4Rs 17 09-10-2019 01:04 PM
Lets talk HIDs patricksheehy 4th Gen T4Rs 2 09-12-2010 05:58 PM
now lets talk capaciters 08medic4x4 Engines / Suspension / Wheels / Tires / Audio / Accessories 11 04-02-2010 01:13 AM
lets talk tires urcnj 4th Gen T4Rs 2 08-27-2008 12:14 PM
Lets talk about colors Falls 4th Gen T4Rs 28 01-03-2007 03:00 PM
