Old 05-27-2020, 09:17 PM #166
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by Gull81 View Post
I have heard you can try and search for a vacuum leak spraying a flammable aerosol around all the hoses while the car is running. I used starter fluid and sprayed into the airbox as a positive control and barely noticed a difference, so I am not sure if its the best test.
You can also try a smoke machine, but I don't think a small leak would cause you so many issues.
That works best on major leaks on an intake. The flammable spray fluid test. A vaccuum hose leak can be difficult to find at times. As sometimes the components fail and will create the leak as well. This one of the reasons why Toyota moved to more electric sensors as time when on to get away from vaccum issues.
Old 07-19-2020, 03:53 PM #167
sweet88gt's Avatar
sweet88gt sweet88gt is offline
sweet88gt is on a distinguished road
sweet88gt's Avatar
UPDATE:
So after a bunch of craziness in 2 different threads. A bunch of tests. A slew of parts.
I noticed a low output of the alternator. I went to the junkyard and pulled a unit. Replaced my reman and it looks like that has been my issue.
50 miles in 2 days. Long idle times. Stop and go. Just got back in which I purposely waited for typical Florida monsoon to run the headlights-a/c-radio and run it through its paces. NO CODES
Before it wouldn't idle sometimes for 5 mins in the driveway.
1997 3.4 Limited 4x4 197xxx miles
sweet88gt is offline   Reply With QuoteReply With Quote
Old 07-19-2020, 03:55 PM #168
sweet88gt's Avatar
sweet88gt's Avatar
I will update this thread again if anything changes.
I always hated when I search a topic and no known fix ever happened.
So far so good.
Old 07-19-2020, 04:30 PM #169
So far so good.
Check the brushes in you other Alt and it low replace them and enjoy having a spare.
Old 07-19-2020, 04:51 PM #170
sweet88gt's Avatar
sweet88gt's Avatar
Those brushes didn't look bad to be honest. I pulled those out first thing.
Old 07-19-2020, 05:37 PM #171
VR or diode block then. I’d check the diode block with a multi-meter that has a diode checker and if it checks good I’d replace the VR.
check , fuel , issue , light , today
Fitting 295's Lets Talk WEAK_E90 5th gen T4Rs 17 09-10-2019 01:04 PM
Lets talk HIDs patricksheehy 4th Gen T4Rs 2 09-12-2010 05:58 PM
now lets talk capaciters 08medic4x4 Engines / Suspension / Wheels / Tires / Audio / Accessories 11 04-02-2010 01:13 AM
lets talk tires urcnj 4th Gen T4Rs 2 08-27-2008 12:14 PM
Lets talk about colors Falls 4th Gen T4Rs 28 01-03-2007 03:00 PM
