Old 03-21-2020, 10:22 AM #16
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a glorious beacon of light 4Runner4Leon is a glorious beacon of light 4Runner4Leon is a glorious beacon of light 4Runner4Leon is a glorious beacon of light 4Runner4Leon is a glorious beacon of light
Real Name: Leon
This discussion should include what size TBU folks are using - 199 or 231. 231's seem to have more problems with ABS and soft pedal; very few examples of those issues with 199's.
Also, the primary benefit of TBU is not so much stopping power as it is higher thermal capacity and hence reduced likelihood of warping or fading when going down mountain roads.
The actual braking capacity is not likely to change unless you have crappy brakes - I was able to trigger ABS with the original brakes, and that's the limiting factor.
I'm very happy with my 199 upgrade, but again, not for the stopping power but for less fading and warping.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 Springs | B&M 70264 Trans Cooler | GlowShift Trans Temp Gauge | OEDRO LED Bulbs | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 03-21-2020, 08:33 PM #17
G_Raw G_Raw is offline
G_Raw will become famous soon enough
I agree with Leon. I went 231 route. And after changing my brake booster, T100 master cylinder, stainless braided lines, calipers, rotors, pads, and full bleed with new brake fluid... pedal has more travel but when brakes grab... They grab! First few drives after the full system change I'd press like gradual like normal then do a harsh jerk stop. Now I know when the grab happens. I get no shimmy coming down mountain roads like I used too.
The pedal travel, stiffness, and grab will vary on the many factors at play here.
G_Raw is offline   Reply With QuoteReply With Quote
Old 03-22-2020, 10:45 AM #18
BostonJon BostonJon is offline
BostonJon is on a distinguished road
Originally Posted by leepoffaith View Post
I recently did the TBU with the Powerstop kit from Amazon and I have the soft pedal too!! It stops just fine, but the brake pedal engages slower and lower then it should. I have bled the brakes at least 6 times and still have that feeling. If I press down a little then lift and then repress the pedal it is perfect. I even tried going down a gravel road and engaging the ABS system to get air out TWICE and that didn't do it. I finally gave up and I'm sitting in the waiting area of a Toyota Service Department right now waiting for them to do a brake system bleed with their computer in order to actuate the ABS system and hopefully get the air out. The tech test drove it and felt exactly what I felt and said it definitely should not feel that way. He thinks it's an air bubble somewhere. We shall see!
Please let us know the outcome of your service visit. Iím having the EXACT same symptoms with the 231 TBU.
BostonJon is offline   Reply With QuoteReply With Quote
Old 04-03-2020, 05:28 PM #19
TJake TJake is offline
Real Name: Jake
TJake is on a distinguished road
Real Name: Jake
2008 Tundra brakes
So I recently bought a 99 Highlander edition. I absolutely love it. Itís been supercharged and runs awesome. The only problem it has is the front rotors are warped (at least one is). So I wanted to replace them but have obviously heard the tundra upgrade is the way to go. I am on a pretty tight budget so Iím debating whether I should upgrade or not. I donít tow and donít plan on running anything larger than what I have now (265/75/16). However, I saw a guy online is selling his rotors, calipers, and pads off his 2008 tundra because he is doing a TRD brake upgrade. I am wondering if the second gen tundras brakes are the same as the first gen brakes that everyone is using for the upgrade. He is selling them for $275. From what I can tell it is everything I need for the upgrade so the price seems great. Iím just not sure they would fit and Iíve searched everywhere and canít find any info on the second gen tundras.
TJake is offline   Reply With QuoteReply With Quote
brake , expected , power , tundra , upgrade
Tundra Brake Upgrade: Brake Pads Side Specific? trevo_man 3rd gen T4Rs 3 10-05-2016 11:45 PM
Did tundra brake upgrade and brake pedal mushy. 3rdgenfan 3rd gen T4Rs 5 10-25-2015 08:51 PM
is Tundra brake Upgrade = Sequoia brake Upgrade??? infamousRNR 3rd gen T4Rs 11 02-20-2014 05:22 AM
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 8 06-22-2012 01:52 AM
