03-09-2020, 07:19 PM
Tundra Brake Upgrade
I just did the Tundra Brake upgrade. It went smooth enough and was easier than expected. I don't see too much of a difference in braking power, is that to be expected or is something off?
03-09-2020, 07:33 PM
Which brakes did the vehicle have before? Meaning base rotor size or the larger ones on limiteds/sport models? Bled well and all that fun 'bedding' in stuff done?
2001 Limited 4WD - 328K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
03-09-2020, 09:30 PM
Real Name: Werner
Real Name: Werner
My pedal has always been sort of soft after the tundra brake upgrade but i will tell you what, when you really get into a situation where you need to come to a quick stop, you will thank yourself. Especially if you're running larger tires. Ive had mine for over a year now and I also have no warpage in my rotors to speak of and ive experienced improved performance after breaking in.
The dunes got boring because I couldn't jump. I'm not the type to enjoy someone else's vehicle. So i'm in the process of making making the dunes no longer boring. I guess that involves jumping.... A lot.
I’ve been teeter tottering back and forth weather to do the TBU upgrade or not. Most guys will say it’s a big upgrade but I find so many mixed opinions and a lot of people with bad or unexpected results. I’ve heard everything from soft pedal to the very end, decreased braking performance, one guy couldn’t get the right pedal feel and a shop recommended a master cylinder from a T-100 truck(which is big bucks). Overall I’ve seen a lot of people that have had poor results, but also most claim it was a good upgrade but you don’t hear a lot about better overall performance. Keep us updated
03-09-2020, 09:55 PM
I noticed a huge difference when I did the 199 upgrade. I also changed all the rubber brake lines out for stainless steel braided lines at the same time so that have have also effected the feel of the brakes. Now they respond very quickly, and grab hard (my wife thinks too hard compared to her suburban, which has a soft pedal)
03-10-2020, 10:40 AM
Real Name: Chris
Real Name: Chris
Mountain grades, loaded down for extended overlanding crap = TBU. No more warping tinfoil stock rotors.
AzBub Build2000 Toyota 4Runner Highlander, 4x4, E Locker. 4:30 gears. TRD Taco springs on Tundra 5100s. FJ80 8 wraps/Monroe economy rear lift.
03-10-2020, 10:51 AM
In my experience Toyota oem rotors for 16 inch wheels don't warp. After market do. I vé had oem pads and rotors after trying out over the counter brands and really think it's worth the extra dollars. some swear that the tbu upgrade is worth it. I would prefer rear disc conversion.
03-10-2020, 03:31 PM
I think the antilock brakes need to be triggered to move fluid around and then another bleed/flush needs to be done.
03-10-2020, 07:55 PM
OEM tundra rotors is the best of all worlds. Rear disc conversion is a nightmare on these vehicles, check some of the threads on it. No park brake, pedal feel issues, and to no real benefit that can't be achieved with TBU and properly functioning and adjusted rear brakes.
03-10-2020, 08:08 PM
I followed
@ sleepydad
build and he did a really nice job of rear disc conversion and seems fairly do able.
03-10-2020, 09:13 PM
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
I followed
@ sleepydad
it kind of depends on what your idea of nightmare is I guess. was it a lot of work to get rid of the old drums? yea but I have done it now on 2x trucks and it's totally worth it IMO.
as long as your brakes are working correctly in the first place the mustang sized calipers are a perfect match on these trucks and the ABS works perfectly.
and yes no matter what e-brake setup you do after the fact it sucks but I have never felt like the OEM e-brake on these trucks was a winner.
03-10-2020, 10:47 PM
Real Name: Joshua 3 Bears
that's what worked for me and triggered them several times.
so bled system, went out and bedded in new pads several times through routine....then started stomping on them hard to trigger ABS several times, then bled system again
My TBU included Toyota stock rotors, calipers ( rebuilt) and new heavy duty Toyota pads and shims., stainless lines front and back, switch to synthetic. I have noticed no difference in pedal feel, unless my pedal pressure sucked to begin with....and I have had several people drive my 4runner...who know 4runners....and no one has said a thing about pedal feel. Mind you ….my sons 2017 Tacoma pedal is stiffer.
So just throwing this out there....this winter I had brake problems and it was related to the check valve...prob has nothing to do with your situation
2001 SR-5...bone stock ( for now) bought 12/10/20. thunder cloud metallic,
gray cloth, sunroof.
2000 SR-5 V6 Auto . TOTALED 10/22/20.  Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, 3 inch lift with tundra springs, billies, lc springs tokico shocks, DRL delete, Big 3 wire, full roof rack, TBU, Swapped in Elocker , all synthetic fluid. block, oil pan and tranny heaters, other small junk
03-10-2020, 11:28 PM
I installed the OEM Tundra rotors, OEM brake pads, OEM shims; the only aftermarket part were the calipers. I still have the stock tires so maybe that's why I'm not feeling the difference too much. I did a proper bleed using the power-bleeder but I think they are a little soft now, how can i fix it? I also feel that the travel increased a lot and seems like the brakes grab after a bit of travel and not immediately.
Thanks
03-11-2020, 12:16 AM
You may still be having air in your brake lines if you are having a soft peddle. Activate your abs as mentioned above, quick stops on a wet road or dirt road will kick in the abs, then bleed again.
I too had the same common problem of a lower peddle but, I got used to it. Braking is still awesome.
It was a night and day difference when I changed out 3 of my brake lines with oem's. Didn't know how much the lines flexed until the new ones went on. Another side benefit was my brake fluid stayed transparent/cleaner longer. The 19 yo ones (no outside cracking) were breaking down inside, leaving bits of rubber in the fluid turning the fluid darker in color.
Also keep in mind your steel spare tire could hit your caliper if you ran it. My 231 were slightly shaved when I had my steel spare tire on during a flat situation.
03-21-2020, 08:20 AM
Thanks
I recently did the TBU with the Powerstop kit from Amazon and I have the soft pedal too!! It stops just fine, but the brake pedal engages slower and lower then it should. I have bled the brakes at least 6 times and still have that feeling. If I press down a little then lift and then repress the pedal it is perfect. I even tried going down a gravel road and engaging the ABS system to get air out TWICE and that didn't do it. I finally gave up and I'm sitting in the waiting area of a Toyota Service Department right now waiting for them to do a brake system bleed with their computer in order to actuate the ABS system and hopefully get the air out. The tech test drove it and felt exactly what I felt and said it definitely should not feel that way. He thinks it's an air bubble somewhere. We shall see!
2001 Toyota 4Runner Limited 4x4
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
