Old 03-10-2020, 11:02 PM #1
Road Bull's Avatar
Road Bull Road Bull is offline
Real Name: Ryder
Road Bull is a jewel in the rough Road Bull is a jewel in the rough Road Bull is a jewel in the rough Road Bull is a jewel in the rough
Road Bull's Avatar
Real Name: Ryder
Exclamation Total Chaos Spindle Gusset Brake Clip Relocation Question.
Got some TC spindle gussets welded on and something that I'd been meaning to address has been in the back of my mind. And NOW I remembered.
What did you all do about the clip that holds the hard line on the original spindle? Did you fab another mount point? What did you use?
I read in rickashay's thread, https://www.toyota-4runner.org/3337729-post60.html , that he thought that others used longer Tacoma stainless steel brake lines, getting rid of the 4runner hard lines altogether. Has anyone gone that route. If so, what would keep the lines out of the way and from catching on something?
If things go well, I might be transplanting my old build to the new rig this weekend. So I am trying to tie up all these loose ends before I take my ride apart.
2002 SR-5 in Millennium Silver.
Timeline>> http://www.toyota-4runner.org/3rd-ge...-timeline.html DEAD
2002 SR5 Changeling Build https://www.toyota-4runner.org/3rd-g...ing-build.html
Road Bull is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 12:15 AM #2
turbodudey2's Avatar
turbodudey2 turbodudey2 is offline
turbodudey2 will become famous soon enough
I used the Tacoma extended length braided stainless lines, and eliminated the hard line. It worked very nicely. The lines come with a little mounting tab already attached, so I drilled a small hole in the gusset and routed the line right through the middle of it and secured it with the tab.
'96 Toyota 4Runner Limited 4x4, Supercharged
turbodudey2 is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 12:47 AM #3
midcoma midcoma is offline
midcoma has a spectacular aura about midcoma has a spectacular aura about midcoma has a spectacular aura about
Tacoma brake lines. Mine weren't extended length or anything. Tacomas have a banjo fitting at the caliper instead of a hard line. These spindles are from a Tacoma, so I'm not sure if the mounting tab for the brake line is different or not.
midcoma is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 01:35 AM #4
papabeach's Avatar
papabeach papabeach is offline
papabeach has a spectacular aura about papabeach has a spectacular aura about papabeach has a spectacular aura about
papabeach's Avatar
Not a fancy solution but works for now....zip tie! Longer lines is a better answer for sure.
(SOLD)1999 4Runner SR5, 5spd-R452d 5th, 4x4 “Highlander”
Supercharged, Lifted, Dual cased, Dual Locked, Geared, Armored and more...
Papabeach Mod Thread
(SOLD)1997 Land Cruiser FZJ80
1979 FJ40L-KC
papabeach is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 01:51 AM #5
Road Bull's Avatar
Real Name: Ryder
Road Bull's Avatar
Real Name: Ryder
Interesting... So what year Tacoma braided steel lines am I looking for? Extended or anything? have you had any issues with them? Did they work with your Tundra brake upgrade if you were running TBU?
Wow.. that looks sharp. What lines did you use, What year Tacoma lines am I looking for and what brand did you go with? Are you running TBU? This seems like a fairly straightforward solution. As long as they don't catch on anything, they should be good. How long have you been running this set up?
Old 03-11-2020, 01:52 AM #6
Road Bull's Avatar
Real Name: Ryder
Road Bull's Avatar
Real Name: Ryder
This is another way to keep utilizing what we got. I will have to take a look and see how I want to run it.
Old 03-11-2020, 09:30 AM #7
No issues at all, so far. This is what the routing looked like. They were long enough I chose to go around the outside of the spindle, rather than the normal route inside the spindle. Seemed like it was too sharp of a bend to go inside. Although either way should work fine.
No TBU here. But they would work the same way regardless.
These are the lines I used (by the looks of it, same lines as midcoma too):
Tacoma Brake Lines: Wheeler's Off-Road
They are the regular length for the Tacoma, so they're not marketed as "extended length".
Old 03-11-2020, 10:17 AM #8
What lines did you use and what brand did you go with?
Centric 950.44014
What year Tacoma lines am I looking for?
Anything from 96-02 should be fine.
Yes.
Since 28JUN17
Old 03-11-2020, 12:22 PM #9
Fishwerks's Avatar
Fishwerks Fishwerks is offline
Real Name: Chris
Fishwerks will become famous soon enough Fishwerks will become famous soon enough
Fishwerks's Avatar
Real Name: Chris
I took some big pliers and bent the existing bracket until I could bolt it up. Kinda ghetto, but it worked.
Fishwerks' Photo/Build Thread 2000 SR5 l White on White l 35s l Supercharged
2010 Trail Edition l Salsa Red Pearl l Stock
Instagram
Fishwerks is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 07:31 PM #10
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
Not ghetto at all. It's cheap and effective. It also looks like this. lol
That is my rig. It's got one or two hard wheeling miles on that set-up. lol
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 03:14 AM #11
papabeach's Avatar
papabeach's Avatar
Turbodudey2,
A couple quick questions looking at your pic..
Is that pic at full droop? Do you rub much? I had that kind of spacing and problems with rubbing prior to getting my SCS F5's with 3.5" backspacing...no more problems :-)...just curious what your wheel/tire setup is and if you are having issues.
1979 FJ40L-KC
Old 03-12-2020, 03:22 AM #12
papabeach's Avatar
papabeach's Avatar
theeostericone,
Looking at your pic something about your gusset looks different to me. Is it the angle or were they installed so the access to the UBJ bolt is accessible from the back instead of the front? Maybe these are different than the TC ones I have...or maybe its 3am here and I am confused.
1979 FJ40L-KC
Old 03-12-2020, 10:32 AM #13
That picture was sitting at ride height. It doesn't rub at all. I had 1" wheel spacers for a long time, and just removed them recently. The clearance you see in the picture is without the spacers, and is about 3/16" between the tire and spindle gusset.
When I first removed the spacers, I was also concerned about rubbing at full droop. But after checking I realized the position of the tire relative to the spindle doesn't change as the suspension moves. Which makes sense because the plane of the hub is fixed relative to the spindle. The only thing that would affect the tire position is external loading (road forces), and those will all primarily affect only the lower half of the tire.
Anyway, it doesn't rub. Which is nice because it rides much better without the wheel spacers.
The wheels and tires are the original 16" split 3s with 285 Duratracs.
Old 03-12-2020, 10:39 AM #14
theeostericone,
Yeah, it looks like the gussets were installed on the wrong side (left gusset on the right spindle, and vise versa).
Old 03-12-2020, 05:54 PM #15
papabeach's Avatar
papabeach's Avatar
Good point...I totally wasn’t tracking that...3am post—> poor brain function ..my problems were notable at lower psi for the reasons you mentioned! Glad you have a good fit!
1979 FJ40L-KC
brake , clip , hard , lines , spindle
Spindle gusset Dezerts10 3rd gen T4Rs 20 11-29-2020 11:22 PM
Total Chaos spindle gussets and ball joint UCA’s montijo505 4th Gen T4Rs 5 09-06-2019 05:37 PM
GA-BNIB 2" Total Chaos "Race" Long Travel -Cam/Bucket/Spindle Gussets -Axles/HD Boots av8ter For Sale: Suspension/Wheels/Tires 24 02-26-2017 05:07 PM
Tiny Total Chaos Question txclimber Engines / Suspension / Wheels / Tires / Audio / Accessories 1 03-07-2014 08:15 PM
1st Gen 4Runner Total Chaos SS Rear Brake Line 26" Christopher W. For Sale: T4R Items 3 05-01-2012 06:39 PM
