View Poll Results: What parts did you replace for your knock sensor code?
I replaced only the harness and it fixed the issue.
3 |
27.27% |
3 |
27.27% |
I replaced only the harness and it did not fix the issue, CEL was still on.
1 |
9.09% |
1 |
9.09% |
I replaced only the harness and the affected sensor.
0 |
0% |
0 |
0% |
I replaced the harness and both knock sensors.
7 |
63.64% |
7 |
63.64% |
05-23-2020, 05:17 PM
#31
Real Name: Robert
Real Name: Robert
Originally Posted by Black798
Cheapest place I've found the OEM parts is partsouq.com. All oem stuff. Two knock sensors, harness, and the two lower intake manifold gaskets for 287 shipped and will be here Monday. I'm going to be replacing all the oem stuff after getting a driverside sensor that was stuck on and also adding a standalone knock sensor that's ran off my piggyback so I can actually see the knock count and not just trust the oem ones that are notoriously issue prone with boost.
Hoping with this setup I'll be able to have knock control below 3k rpm and then from 3k up just let the oem stuff do it's thing and monitor to make sure it's all working properly.
I've not dealt with partsouq yet; but have used amayama from Japan several times with good results. Yesterday I ordered the following from amayama UAE:
2x: 89615-12090 OEM Denso knock sensors $98.75 ea
2x: 17177-62060 OEM lower manifold gaskets $22.49 ea
Shipping: $23.50
I'd ordered the wiring harness 82219-34010- $28.84 from Conicelli with a bunch of other stuff a week prior. No rush with delivery needed for me as I've chosen to replace these prophylactically as part of the VC gasket, timing belt and SC install work.
I am very interested in your plan for an addl. knock sensor as in input to your mapecu3 for tuning below 3k rpm. I also plan to purchase a map piggyback when I drop to a 2.2 pulley as a next step.
From what I've gathered lately, modern knock sensors (e.g. NTK) are designed to provide flat response from 5k-15kHz to meet many applications and rely upon the engine manufacturer to process the signal to meet the specific need.
I read some stuff on customtacos.com that the 5VZFE knock has a peak frequency of 6.6kHz, so you'd need to do bandpass filtering to create a useful input to the piggyback. Presumably, the OEM ECU has that functionality built in for its own needs.
I found this whitepaper by Texas Instruments very interesting:
How to set-up a knock-sensor signal-conditioning system
And this link for the evaluation board ($149), software and documentation:
Vibration and Engine Knock Sensor Interface
I'm also wondering whether it would be possible to tap onto, buffer, condition and utilize the signals from the existing sensors as inputs to the pigyback.
I'll keep poking around on this and please keep us updated on your findings.
1999 SR5 Cali Auto - Jade Mica. TRD SC w/ MAPECU3, Supra Blue Injectors, Denso EVO 9 FP, Borla Cat Back, Magnaflow & Gesi G-Sport Cats, Airaid ISR Delete, Deckplate Mod, 231 TBU, SCS Stealth 6 Silver w/Firestone Destination X/T LT255/75R17. 4XI Rear Bumper.
05-24-2020, 09:59 AM
#32
Real Name: Phoenix
Real Name: Phoenix
Shipping: $23.50
Definitely will post the results in a few weeks once i get it up and running again. Pretty sure I know the thread you're talking about over on CT, read through that a few times when I was exploring the option of ditching the stock sensors all together.
Also heres the mapecu wiring diagram for the knock sensor setup, it already uses the gm knock sensor processor so that simplifies things. I wonder if you could run the stock sensors through that gm processor to the mapecu and just use them instead of that 3rd sensor. The one thing I am struggling to figure out is how to setup two sensors off that gm system. Not sure if I can just run them both off the same wire or if I am better off doing just one sensor in the middle of the cylinder valley. If I had to pick one side for mine to put the sensor I think the driver side would be best since thats the sensor that failed and leads me to believe the side that knocks the most. Very glad I choose the mapecu over the urd 7th or something, its really nice having a piggyback with this much capability
98 Limited - Solid Axle Swapped,Turboed,And On 37s - Build
Transgo Shit Kit Writeup - Click Here
05-25-2020, 01:38 AM
#33
Real Name: Jerod
Real Name: Jerod
Is there really a need for knock control below 3K RPM? On stock sized tires (realize if you have larger tires but same gear ratio this could be an issue), I don't spend hardly any time with heavy driving under 3K except when going up the pass on I-80 towards Tahoe. Even then just popping out of overdrive takes care of that.
When I want to go fast, 3K RPM's comes and goes really quick...
05-25-2020, 01:03 PM
#34
Real Name: Phoenix
Real Name: Phoenix
My truck is re geared to 5.29s but it weighs a little over 1200lbs more than stock and is twisting 35s. I dont like climbing long passes like on I70 screaming at 4k rpm in 3rd to maintain 60. At that point the blower isnt even making boost so what was even the point of installing it. I like being able to hold 65 to 70 at 2500 to 3000 rpm when climbing most hills. I have a shift controller that allows me to force the torque converter to stay locked and in 4th gear. Works really well and its nice not downshifting on every damn little hill I come across. Basically treat it like my turbo car where boost is what carries me up things and vacuum does the rest. So in my case knock control below 3k rpm is really important
06-05-2020, 03:45 PM
#35
Originally Posted by MikeDiehl
So, I just put my truck back together after replacing both knock sensors, knock sensor wiring harness, fuel injector O-rings, valve cover gaskets, spark plugs, and various hoses...
Now, the truck smells like gasoline and the throttle peddle seems stiff.
When I started it for the first time, I let it get up to temperature. The fuel line coupling behind the battery was dry to the touch. No visible leaks around the intake manifold. When I put it in gear, the idle fell to about 750rpm. So, I'm not thinking I have a vacuum, fuel, or coolant leak. But that gasoline smell is... unnerving...
Any advise would be welcome.
Mike.
So, last Saturday, I got up early and tore back into my truck. I replaces the o-rings. Only this time, I put a bit of 3-in-1 oil on them. This helped A LOT! It also helped to have the intake still on the engine this time!
I quit around noon because it got too hot outside. Worked on it a bit that evening. Then started again at about 11 on Sunday.
The truck was running by 3:00PM!
So now I have a 24 year old truck that runs better than it has in YEARS!
I've been driving it for a week now. No gasoline smell. No CEL. Plenty of power. NO hesitation. Never stumbles. Idles smoothly. Hits 85mph sooner than I'd like to admit.
I'm pretty stoked.
Thanks, all.
Mike Diehl.
06-05-2020, 05:23 PM
#36
What shift controller do you have?
10-14-2020, 11:40 PM
#37
add me to the list, I am getting both codes on each side or it was the gas, I never had problems till I filled it up at walmart 2 days ago
10-15-2020, 12:00 AM
#38
Real Name: Devan
Real Name: Devan
I'm assuming you cleared them and they came back? If not, give it a whirl, and maybe once more after you refill the tank if it doesnt work. What's the car and mileage anyways?
10-15-2020, 12:11 AM
#39
Kept clearing, but comes back very random, even just cruising on a back streets, 2002 with 250k, supercharger.
10-15-2020, 10:39 PM
#40
Real Name: Devan
Real Name: Devan
Sounding very familiar. Another very easy test - if you're able to - is to swap ECUs with somebody driving a similar vehicle and see what happens (I just bought one off ebay for $100). Unfortunately theres not much you can do without taking the intake apart, so might be best to wait until the tank's empty and toss in some fuel cleaner. If you have an oscilloscope, hook it up and check out what the waveform and frequency is - I forget exactly but it should be in the TSM. If it's too inaccurate, inconsistent, erratic, weak, or generally not within damn good spec, it's not good.
Could try sparks/coils, or injectors, but I assume that probably crossed your mind already.
It's been a while so my memory on it's kinda gone but there's tons of information in my old thread along with many others, I imagine you'll get it done pretty fine. I'm not sure how much a supercharger would affect things, so hopefully it doesn't bug you too much
10-15-2020, 11:02 PM
#41
Wanted to add that I do have a URD piggyback. When I get time I will disable it and see what happens.
10-16-2020, 09:47 PM
#42
add me to the list. Mine just popped up. I'm DREADING doing this job...
00' 4Runner Limited- Auto trans, E-locker, grey-wire mod, custom rock sliders, B&M 70268, TRD exhaust tip, 285/75/16 Duratracs
R.I.P 99' 4runna- auto trans, 4wd, tacoma whip mod,B&M 70768 tranny cooler, 265/75/16 Cooper Discoverer at3
10-16-2020, 09:58 PM
#43
[QUOTE=Bdnewyork;3493988]I've not dealt with partsouq yet; but have used amayama from Japan several times with good results. Yesterday I ordered the following from amayama UAE:
Shipping: $23.50
Thanks for providing these links! I was about spend about $188 from Mcgeorge!
Reason: wrong quote
11-02-2020, 02:34 AM
#44
Going to be replacing my 2 knock sensors and wiring harness here soon. As far as parts go, replacing 2 sensors, wiring harness, fuel injector o-rings, 2 lower intake manifold gaskets. Anything else I need to replace while I have everything off?
11-02-2020, 09:39 AM
#45
Real Name: Devan
Real Name: Devan
Gonna need a throttle body and intake plenum gaskets. Good time to do your valve cover gaskets too. I believe the O-ring for the banjo bolt on the fuel rails, or something along those lines, is technically non-reusable but I was unaware of this and haven't experienced a leak. Still might be worth looking into.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
