Old 03-13-2020, 10:19 AM #1
MNYota MNYota is offline
MNYota is on a distinguished road
Lift Question
Hey all,
01 SR5 here. Wanted to add a “little” lift to keep tired from rubbing. It’s a daily so I just need an inch or two. Probably just going with coil spacers. How much can I safely add without changing anything else?
Thanks in advance!
MNYota is offline   Reply With QuoteReply With Quote
Old 03-13-2020, 10:45 AM #2
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Coil spacers won’t move your bump stops, so won’t prevent rubbing.
Probably your best bet without doing anything else would be to get a properly sized tire, or properly backspaced rim.
Those would be one and done type moves.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 03-13-2020, 01:16 PM #3
Ditto. Also, get the front end aligned for max caster for more clearance at the back of the wheel well.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-13-2020, 05:55 PM #4
Thanks everyone. Not actually trying to lift for bigger tires, but the ones I have are “slightly” bigger than stock and are rubbing on the mud flaps just a touch.
Just hoping to raise it up enough so that stops. Probably only need an inch or two. Just hoping the spacers would be an easy and cheap option to gain a “little” clearance.
Old 03-13-2020, 05:58 PM #5
00Spork's Avatar
00Spork 00Spork is offline
Real Name: N3ZZAR
00Spork is on a distinguished road
00Spork's Avatar
Real Name: N3ZZAR
You could also trim as necessary for more tire clearance.
I'd assume that you'd have to get longer shocks in the rear if you did want to do spacers front and back, and possibly extend your rear brake lines. Front should be able to handle a 2" spacer lift with no other modifications other than an alignment.
00Spork is offline   Reply With QuoteReply With Quote
Old 03-13-2020, 06:58 PM #6
The wheels travel in the same arc no matter the ride height. They will rub even after a small lift. Just get an alignment and have them "max" the caster. No parts needed (unless your alignment cams are seized).
Old 03-13-2020, 07:02 PM #7
FrogginAround's Avatar
FrogginAround FrogginAround is offline
FrogginAround is on a distinguished road
It sounds like a 1 inch body lift is what you are looking for. That will give you the clearance without having to touch your suspension.
96 Stellar Blue Pearl Limited. 5VZ-FE. 290k. Auto. E-locker. Small lift.
FrogginAround is offline   Reply With QuoteReply With Quote
Old 03-13-2020, 09:57 PM #8
Maybe if you let on what size your tires are and what rim setup folks could provide better answers.
Old 03-22-2020, 11:15 AM #9
Thanks for the advice!
1. How much “body lift” can I add without changing anything? Or should I just stick with stock? A few of mine are SHOT! But, if I’m going to replace them, I’d like to add a little lift, but don’t want to have to modify anything else.
2. Where would you guys recommend purchasing these body mounts? Poly or stock?
Thanks again everyone!
Old 03-22-2020, 11:52 AM #10
Iffykid Iffykid is offline
Iffykid is on a distinguished road
No help here, I have a 00 Limited and went from stock 265/70/16 to 265/75/16 on stock rims without rubbing. How big of slightly bigger tires did you go?
Iffykid is offline   Reply With QuoteReply With Quote
Old 03-22-2020, 01:33 PM #11
Exactly the same set up but mine is an 01 with stock rims. Just replaced shocks/coils all the way around too. Body mounts are shot though. Going to replace them, but thought I might add an inch or two if I am going through all that anyway.
Just don’t want to have to modify anything else.
Old 04-03-2020, 08:47 AM #12
Bump.
Any thoughts on how much body lift I can add without having to modify anything else? Or just stick with stock height? If I’m going through the trouble to do it, might as well benefit from a little more height?
Also, where to buy? Stock rubber or upgrade to poly?
This is a daily driver by the way. Doing this soon so all recommendations and advice are welcome! Thanks!
Old 04-03-2020, 11:08 AM #13
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
Bump.
I just installed a 1" body lift from 4crawler to reduce tire rubbing. Get the steering spacer with the kit. At 1", you won't need to modify anything else, just readjust your shifter linkage, remove the lower fan shroud, and redrill the bumper holes. I think that I can actually put the fan shroud back on and still have about a 1/4" of clearance, so I might try that.
The kit was around $130 with tax and shipping. Very easy to do, especially if you're going to be replacing your bushings anyway. I reused my OEM bushings, so can't comment on poly vs OEM.
I'd recommend a 1" BL in your situation, that should fix your rubbing issue.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 04-04-2020, 01:37 PM #14
Did you replace shocks and coils with oem? My 00 has originals and I am looking to replace but trying to get about 2" of lift at the same time.
What is the snow conditions north of Duluth? I am considering a trip up to Tofte-Carlton Peak just as an excuse to get out of the house this weekend.
Old 05-03-2020, 04:35 PM #15
SilverBullet8404 SilverBullet8404 is offline
Real Name: Luke
SilverBullet8404 is on a distinguished road
Real Name: Luke
If you're gonna lift it, don't go spacers. Save the money and once you have enough, buy the 5100s/OME combo
SilverBullet8404 is offline   Reply With QuoteReply With Quote
add , coil , lift , safely , spacers
One more Bilstein 5100 front lift, 0 rear lift question. Hugo Stiglitz 5th gen T4Rs 31 08-07-2020 10:29 PM
Basic Lift Question - read all the lift info threads BXPhoto 3rd gen T4Rs 11 01-02-2017 09:34 PM
Air Lift 1000 and Lift Question - Spring Seats G8RB8_12SR5 5th gen T4Rs 4 08-24-2014 11:15 PM
quick question, do i need body lift for arb and ome sus. lift? theizzardking 3rd gen T4Rs 7 10-16-2010 12:54 AM
Wheels Question and Lift Question. K6UK Engines / Suspension / Wheels / Tires / Audio / Accessories 22 02-12-2007 11:45 AM
