I purchased the wrong injectors (23250-20010) for my truck and am wondering if they are compatible with a N/A 5vz? They are for the 3.0 engine in a van or Camry. 15cc more than stock. Any helpful input would be appreciated.
‘97 SR5 2x4 177k | Front: Bilstein 5100+toytec 600# /Rear: Fox 2.0 Performance Series Struts+SuperFlex coils, JBA UCA, Whiteline LCA bushings, OEM Ball Joints, Tie Rods, and Front Links, 2nd Gen Rear Links, T-Belt, T-Stat, Water Pump, B&M 70268, 295/70/17 Nitto Trail Grappler Wrapped GX470 wheels, UltraGauge, Trans Temp Gauge, HID Retrofits, Recycled Barn-Door Cargo Drawers, Home-made Doggy Divider, Satoshi Inspired Grille, Max-life ATF, Toyota Red Coolant, 5w-30 Pennzoil Ultra Platinum w/20% HD Hyper-Lube, eBay Window Visors, Tint, $20 Walmart Keyless Entry, Cheap Alpine H/U and Speakers, Bed Liner’d frame, and a whole bunch of fishing gear.
Have the part number for those injectors? Figure you did it for the supercharger?
Yeah I used 23250-46030 from some Lexus/Supra models. But if you want to keep the engine's air assist fuel atomization, the "blue top Supra" injectors 23250-46050 are better. If I were to do it again, I would have put these in since they put out a spray instead of a stream.
Great timing! I plan to spend a weekend this summer taking my S/C off and servicing the nose cone, fuel system, and such while I am in there. Injectors have been on my mind since my rig has 340k miles on it now.
I don't know if you are familiar with our channel, but we have several videos that will help you with your planned work.
__________________ "My old man is a television repairman, he's got this ultimate set of tools. I can fix it!"
Oh yeah I have watched more than a few of the videos. One of these days I hope you do one on replacing the bearings on a 3rd gen 4R / 1st gen Taco front spindle.
