03-15-2020, 10:35 AM
New Truck ball joint mystery
So I picked up a 2000 that has some obvious upgrades. trying to figure out what the previous owner did with the ball joints here and where I can get replacement parts since they are obviously not stock.
96 4 runner 3.4L SR5, Borla Touring catback, Rough Country 3 " Suspension (new kit), Powerstop Extreme Towing brake kit, B&M super cooler and Koyo radiators in series, 31" Michelin LTX A-2 tires, Barnes 4x4 heavy duty rear Differential cover. Taco tie rods and upper and lower ball joints
03-15-2020, 10:40 AM
Real Name: Robert');DROP TABLE Students;
Those are SPC upper control arms with their proprietary upper ball joints. You can get replacement ball joints from Wheeler's, Amazon, etc. I've got a set on mine and really like them, but order two sets of replacement UBJs - one to install, and one to keep as spares. The lead time to get them is a few days at least, and if you need a set, you're stuck until they show up.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
03-15-2020, 10:49 AM
You are the man. Much thanks brother. I knew I could count on this forum.
03-15-2020, 10:57 AM
I see some extended length joints as well. Wondering if they would make sense? I have a 3 inch lift and a 2 inch body lift. I do alot of off road travel as I live in the 4WD area of the Outer Banks.
03-15-2020, 11:45 AM
What do you mean extended joints?
<- Wilmington area native who misses the beach like crazy.
03-15-2020, 01:14 PM
Extended ball joints. They have a set with an extended stem. I don't suppose I need to get into all that. The only thing I'm having trouble with is the part number. Nothing on the part itself. I see a 25001 and a 25002 that look identical except for the new grease fitting.
03-15-2020, 02:39 PM
25002 doesn't fit the 25460 arms.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
03-16-2020, 06:25 AM
OK so then I'm guessing I must have the 25460 arms and that we're ta;king about the 25001s?
03-16-2020, 06:27 AM
...and yeah, you gotta get back down East brother...
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
