Old 07-02-2012, 04:00 PM #1
CanadianTRD's Avatar
CanadianTRD CanadianTRD is offline
CanadianTRD is on a distinguished road
Power Seat Repair - Stuck or Barely Moving - DIY Writeup w/pics
When I purchased this rig, the power seat on the driver's side was barely moving. I tried to force it, thinking there may have been obstructions in the threaded rod or in the track...this definitely made it worse. It proceeded to only move on the passenger side track (quite flawlessly) yet would not move at all on the driver's.
Upon inspection, this is what I found and how I repaired it!
What your seat looks like underneath:
The threaded rod assembly removed (2 bolts on the main bracket, 1 nut on a stud somewhat hidden on the exterior frame):
Removing the driver's side assembly (this turns the threaded rod after the motor turns the "driveshaft":
The assembly with the bad part inside:
Guide Pin removed, note the small rotating "drive" pin, this is removable and can be attached to the "driveshaft" or the rotating gear bolt:
Assembly opened up:
Note how the gears rotate eachother:
More opened up pics:
The bad part, a NYLON threaded gear:
Washers removed that it rotates on:
See the gear teeth totally destroyed:
And my donor part from the passenger seat:
Reassemble and enjoy!
Why not clean your carpets while you are at it!
-'97 Limited 3.4 4A, Loaded, Rear E-Locker, Alpine 9813, Debadged rear, Graphite Split 3-Spokes, '99 Center Console, Black on Chrome (35x,xxx KM)
-'98 Limited 3.4 4A, Loaded, PIAA Fogs, Rear E-Locker, Desert Dune on Desert Dune (Family rig since new in 1997, currently 29x,xxx KM)
-'89 SR5 Convertible, Red on Chrome (deceased 2010, Head Gasket, sold)
-'93 Jeep ZJ 5.2L NP249 (23x,xxx KM)
CanadianTRD is offline   Reply With QuoteReply With Quote
Old 07-02-2012, 04:14 PM #2
Jungoes's Avatar
Jungoes Jungoes is offline
Jungoes is on a distinguished road
Jungoes's Avatar
thanks for the pictures! good to know if i ever get problems with the seat movement,
just a quick question, but the damaged worm wheel, did you notice it dry with out lubricant when you took it out?
2000 Limited, 2021 SR5
Jungoes is offline   Reply With QuoteReply With Quote
Old 07-02-2012, 04:19 PM #3
I wouldn't say "dry" but that yellow stuff from the factory was definitely "caked"
Everything felt lubed before and after so I didn't mess with it and the seat as it stands today moves very quickly and smoothly. That grease is lifetime non-maintenance type I do believe.
In retrospect it may have been wise to clean all those gears out and re-lube...but I am not worried.
In my opinion, the failure was a result of an obstruction at some point, and the subsequent "forcing" of the seat back and forth leading to gear destruction. If it were normal wear and tear, the gear would be worn all the way around...it was only worn in two identical spots on opposite sides...the remaining 50% of the gears were intact and normal.
Old 09-07-2015, 04:17 PM #4
sigley0527 sigley0527 is offline
sigley0527 is on a distinguished road
In case anyone is interested, you can also remove the seat and manually adjust the placement with a 22mm wrench. This is what I did considering I didn't want to remove the passenger seat to obtain the donor piece. Eventually I'll replace the nylon gear, but for now I just wanted to readjust to a comfortable seat position considering my step mom moved the seat all the way forward and of course thats the position it broke in.
sigley0527 is offline   Reply With QuoteReply With Quote
Old 09-07-2015, 04:26 PM #5
Just make sure both rods are aligned so the seat placement is straight.
Power Seat Repair - Stuck or Barely Moving - DIY-20150907_131915-jpg
Old 09-07-2015, 06:04 PM #6
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
Awesome description of a problem I'm sure we will all eventually have...
mine moves fine but it sounds like sand is in the guides or on the rod itself?...
not too worried until it doesn't work anymore i suppose
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 10-12-2015, 08:58 PM #7
Snacksquatch Snacksquatch is offline
Snacksquatch is on a distinguished road
Does anybody happen to have a part number for the motor for the power seat?
I just bought a 2007 SR5 and the seller had installed Limited power seats in it. Well, long story short, he never finished the install on the passenger seat, and when I took it in to have the power hooked up (which I was assured was all that needed done...)it turns out that the motor is bad and is blowing the circuit every time it is activated.
Im having a bear of a time finding the actual part on Google or on here using the search, just wondering if there is an easy part number anywhere?
'07 SR5, nautical blue metallic, OME 885 coils, Bilstein 5100's front and back 255/75/r17 Duratrac's, Pioneer AppRadio 3, 10" JL Audio sub/amp combo, Rola rack, Powerstop Z23's slotted and drilled, RCI Metalworks front skid, 4xInnovations sliders w/kickout
Snacksquatch is offline   Reply With QuoteReply With Quote
Old 10-13-2015, 12:44 PM #8
After some searching I found this and think its the right part. It shows it for a 2004 on one site and 2007 on another, but as far as I can tell they are the same part:
https://www.parts.com/index.cfm?fuse...nt-Right-MOTOR
In case anybody else runs into this issue, hopefully the part number helps. Thanks all!
Old 10-13-2015, 01:06 PM #9
StreetCreeper's Avatar
StreetCreeper StreetCreeper is offline
Real Name: Woody
StreetCreeper will become famous soon enough StreetCreeper will become famous soon enough
Real Name: Woody
4th gen guys might find this info more useful.
StreetCreeper is offline   Reply With QuoteReply With Quote
Old 10-13-2015, 01:12 PM #10
Good call, can I move my post or does an admin need to?
Old 10-14-2015, 09:25 AM #11
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Why move the thread to 4th gen??? It Started off as a 3rd gen problem & solution with pics. Sasquach, please go post on 4th gen. :^)
Old 11-25-2015, 05:46 PM #12
ecruthis ecruthis is offline
ecruthis is on a distinguished road
I have a power problem but it is on the reclining protion fo the seat. hte back and forth work perfect. But the reclining doesn't even move or make a sound. Like it doesn't even have power. I haven't gotten the gull to remove the seat and check it out as i know nothing about electrical stuff.
Anyone run into this. I can not find a thread specific on this top of just the reclining part. Thank you in advance for any info
ecruthis is offline   Reply With QuoteReply With Quote
Old 01-31-2016, 10:25 AM #13
Cttein2 Cttein2 is offline
Cttein2 is on a distinguished road
Reclining seat problem
I have a 2006 Ford sport. The front power seat will not recline. It will incline forward. But will not recline. The other power functions all work correctly. Took the seat out and can get to the motor. Did not disassemble it though. Any suggestions for the fix?
Cttein2 is offline   Reply With QuoteReply With Quote
Old 01-31-2016, 10:26 AM #14
Sorry
The auto correct say Ford. Should say 4Runner
Old 08-10-2017, 02:25 PM #15
stever1000 stever1000 is offline
stever1000 is on a distinguished road
Good info I will try adjusting mine with the 22mm wrench manually first.
stever1000 is offline   Reply With QuoteReply With Quote
power seat dyi , power seat failed , power seat problems , power seat repair , power seat stuck
Leather Seat repair Az4runnin 4th Gen T4Rs 2 05-12-2012 03:28 PM
Moving Driver's Seat biglar 3rd gen T4Rs 9 10-13-2009 04:16 PM
power antenna is stuck podzhopnik Classic T4Rs 3 06-04-2009 10:09 PM
Moving AC Power and Diff Lock Buttons aerochip 4th Gen T4Rs 19 04-09-2008 09:24 PM
Rocking/moving driver's seat? coolpop Problems & Warranty Issues 14 12-11-2003 08:54 PM
