Old 03-17-2020, 12:04 PM #1
Toy2play Toy2play is offline
Toy2play will become famous soon enough
Bilstein 5160: Tundra vs 3rd gen 4runner
I'm looking to upgrade my rear bilstein 5100s on my 3rd gen 4runner. I'm curious the differences between the tundra 5160 and the 4runners. Is the tundra designed to run more weight and thus will be on more stiff on a runner? I noticed that the sizes of the reservoir are different and wonder if the tundra has more oil capacity. Would love as much oil capacity as long as it didnt compromise the ride too much. My main reason for the change is that I overland a bit in my runner and my shocks regularly heat up after hours on the trails.
I'm running the OME 906s with 2 trim packers in the rear for about ~2.7 inch lift. Front is Eibach coils with 5100s I believe. Probably eventually change out the front with 6112, but that would be later down the road. 4runner isnt a daily driver so the ride stiffness isnt a huge deal breaker.
Anybody have a chance to test out both versions?
97 Charged, lifted, armored, geared, locked SR5.
Toy2play is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 12:21 PM #2
A big thing to note is the different lengths between the 4Runner and Tundra application - the Tundra shock is longer (compressed is ~0.9" longer, extended is ~2.5" longer). You'll need to make sure your 906s are long enough and your bump stops are long enough to run the Tundra shocks.
Hopefully somebody else can chime in on valving, though I remember hearing the Tundra 5100's are a bit softer than the 4Runner 5100's, which should have comparable valving to the 5160's.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-17-2020, 12:34 PM #3
I have extended my bump stops in the rear with my current setup maybe I'll have to do a little more research. I'm curious what the lift minimum is with the 5160 tundra shocks, 3 inches? What's the best way to determine if you are in the correct extention/compression, jack up one side until maxes out on the bumpstop and then measure the distances?
Old 03-17-2020, 01:18 PM #4
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
I've never read a thread on this forum about 5160s honestly. I looked into them myself and checked here and nothing but that was also 6 months ago. Good luck I'll stay tuned!
The dunes got boring because I couldn't jump. I'm not the type to enjoy someone else's vehicle. So i'm in the process of making making the dunes no longer boring. I guess that involves jumping.... A lot.
VernySanders is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 02:13 PM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
That is correct. Obviously from where the shock mounts at. For most accurate readings remove a shock but not required. If you know your current shock measurements you can also go off that. Flex it in and see how much you have left before bottoming out, add that number to your current shock's compressed measurement, and that is the longest your collapsed shock length can be. I'd recommend a 1/2"-1" safety buffer for when your bumpstops compress more.
Old 03-17-2020, 03:34 PM #6
Worst case for bump stops (for shock length) is full compression = remove springs and put weight on rear axle (jack it up with diff). Worst case for tire clearance is full flex (jack it up on one side). Both are concerns, depending on wheel/tire/shock setup.
As long as the spring doesn't fall out at full droop, you should be fine flexing.
If you have the boot off the shock, you can see how much travel you have left. Make sure you leave the boot holder in place for the right measurements.
You are probably going to have to do these measurements yourself...
Old 12-25-2020, 05:15 PM #7
culiced culiced is offline
culiced is on a distinguished road
which one did you end up going with? tundra 5160 or fj/4th gen 5160? im gonna be running 861 springs. did you ever measure the compression and extension of you shocks?
culiced is offline   Reply With QuoteReply With Quote
Old 12-28-2020, 01:38 PM #8
Fiffa's Avatar
Fiffa Fiffa is offline
Fiffa will become famous soon enough Fiffa will become famous soon enough
Fiffa's Avatar
What about 4th gen 5160's? That's what I'm running and I love them! When I was researching I found that the extended travel 5100's are just 4th gen standard length:
33-187174 ("long travel" 3rd gen/standard travel 4th gen 5100's):
Collapsed Length (IN): 14.91
Extended Length (IN): 23.5
25-227611 (4th gen standard travel 5160's)
Collapsed Length (IN) 14.83
Extended Length (IN) 23.5
I'm running Dobinsons C59-210v's (~4"; similar lift to OME 861's but progressive) and they are a match made in heaven - not too rigid and not too squishy. The only thing that was different was the lower mount. It's wider than the 5100's I took off, but the bushing is more narrow so they end up working fine with the stock mounting point.
'00 'Get Lost' Build
IG: get_lost_fiffa
Fiffa is offline   Reply With QuoteReply With Quote
Old 12-28-2020, 06:18 PM #9
I scratched the idea for now. This year hasn't been the best for doing upgrades. Current setup works for now and I'll revisit this when the need is there. I never ended up measuring the shocks either.
4runner , bilstein , capacity , oil , tundra
Bilstein 6112 Strut Spring Assemb + 5160 Reservoirs Set 03-09 4Runner 4WD 1.9" meltdowner 4th Gen T4Rs 2 10-07-2018 10:28 PM
Bilstein 5160 Rears - 12k miles - Valved for 4runner danielhfranks For Sale: Suspension/Wheels/Tires 0 09-06-2018 12:42 PM
