Old 03-17-2020, 06:11 PM #1
ctoombs ctoombs is offline
ctoombs is on a distinguished road
Help diagnosing squeal/chirp
Hi all,
Trying to diagnose a chirp that seems to be coming from my accessory belts.
Captured a video here and hoping y’all can help point me in the right direction.
Belts are tight and tensioned correctly, alternator was replaced recently. Timing belt and water pump replaced not long ago either.
My initial suspicion is an idler going bad but not sure what one or if that’s the case for sure
Video is linked belowStrange squeak 99 4Runner - Album on Imgur
ctoombs is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 10:20 PM #2
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
When does the noise happen? At start up or other time
plcfcng is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 10:21 PM #3
At idle once warmed up all the way.
Old 03-17-2020, 10:53 PM #4
spartacus's Avatar
spartacus's Avatar
Sound to me like a'pulley bearing going out or misaligned. Any work done on the engine recently? To me it seemed louder near the fan clutch pulley. take one belt off at a time and see if you can narrow it down.
Old 03-17-2020, 10:55 PM #5
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
These engines are really nice because they have a belt for each accessory, so you can easily troubleshoot the noise.
Just start removing the belts 1 by 1 until the noise goes away.
If you get all 3 belts off, and it's still there, you know it's something behind the timing cover.
Easy peasy!
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 11:13 PM #6
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
Smile
A easier way is to use a spray bottle with windex start the engine spray each belt one at a time and listen if it’s a pull-up noise it will quite down for a bearing a section of Heater hose may help locate the noise or as mentioned above remove each belt one at a time. Hand spin each item. The ac idler pulley can be repacked with grease in a pinch
Old 03-18-2020, 08:05 PM #7
Bit of an update: ran an errand today where I got fully up to temp, and lo and behold, zero noise.
Now the interesting factor here is it’s 20 degrees warmer today (60) vs yesterday (35-40).
Gonna definitely get into it and see what’s causing the chirp, will report back once I get to the bottom of this.
Old 03-18-2020, 08:59 PM #8
shadow247's Avatar
shadow247's Avatar
Please let us know what you found. There are so many threads where people give different kinds of advice, and OP never responds if they tried any of it, or if they even fixed the problem.
The 4Runner Show
belts , initial , replaced , timing , video
Diagnosing AC squeal Kyngfish 3rd gen T4Rs 18 11-28-2016 10:59 AM
Key fob locks three, no chirp Reata 5th gen T4Rs 10 02-03-2015 07:24 PM
Quick chirp awthorn 3rd gen T4Rs 10 05-10-2014 09:34 PM
how can i turn off my chirp? 4rnr4me 3rd gen T4Rs 17 02-26-2008 07:23 PM
*chirp, Chirp * Bobby Northeast 27 10-06-2006 07:47 PM
