Old 03-17-2020, 08:21 PM #1
Red October Red October is offline
Red October will become famous soon enough
Vibrations, and not the good kind.
Hey fellow 4Runner enthusiasts, I have a problem.
Recently my truck started putting out some pretty serious vibes, not in a good way. 97 4Runner, 2.7 5 Speed, 4x4, 270K miles.
What happens is it vibrates, almost like an out of balance drive shaft or a bad u-joint. The vibes increase with vehicle speed, not with engine speed. They are also more pronounced when the truck is under load, or oddly enough, coasting or in a gear too high (like when you would need to downshift on a grade), usually cruising minimizes the vibes but does not eliminate the shake.
I have checked my wheel balance. Checked and serviced the cv joint and drive shaft u-joints, front and rear, they are in pretty good shape with no apparent slop. The truck doesn't feel like it has pinion bearing play. My gear set seems a little worn, but not horribly bad. The problem seems like it has grown over time, but after a recent multi state road trip, probably 2000 miles or so, it is significantly worse than before.
Anyone experience anything like this before? Ideas. To my mind it seems like the problem could be in the transmission output/ transfer case areas, but how could I check this theory without taking stuff apart? Does anyone know where to get transfer case rebuild parts for these? (R100 I believe, not to be confused with its RF1A gear driven brethren)
If ya always do what ya always done, Ya always gonna get what ya always got.
Red October is offline   Reply With QuoteReply With Quote
Old 03-21-2020, 01:44 AM #2
Scratch and dent's Avatar
Scratch and dent Scratch and dent is offline
Scratch and dent is on a distinguished road
Do you have any suspension modifications?
5th gen V2 (Safetymobile)
Scratch and dent is offline   Reply With QuoteReply With Quote
Old 03-21-2020, 08:40 AM #3
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Easy thing to rule out driveshaft, pull it out, check all the joints. To confirm issue of joints/balance, drive your rig around in 4x4 without rear shaft so its just in front wheel drive.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 03-21-2020, 09:45 AM #4
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
If he's got it lifted and it's actually a CV issue, this might make the vibrations worse. Or just highlight another issue. It did for me, at least. hahahahahafml.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 03-21-2020, 09:56 AM #5
dogtail's Avatar
Real Name: Keith
dogtail's Avatar
Real Name: Keith
We'll in order to check condition of the rear shaft it needs to be pulled out. Driving in just front wheel drive, you definitely get torque steer, but it has its place in trouble shooting and field dressing in a pinch.
Old 03-21-2020, 10:14 AM #6
thezentree's Avatar
thezentree's Avatar
Oh, I'm not disagreeing at all, just sharing my experience. Doing this is actually what clued me into my front end contributing to the vibrations (RWD vibrations started at 65-70mph, FWD vibrations started at 50-55mph and were significantly worse).
gear , good , problem , speed , vibes
Vibrations on '10 sr5 jibaro 5th gen T4Rs 36 08-16-2016 06:41 PM
Chasing Down some Vibes, and I don't mean "Good Vibrations" :D TheFriZ 3rd gen T4Rs 24 11-16-2014 11:12 AM
Bad Vibrations ToyNutt 3rd gen T4Rs 7 05-05-2011 09:27 AM
I am not feeling good vibrations buck_sez 4th Gen T4Rs 3 02-25-2010 12:51 PM
Vibrations 03 2WD V6 Oscarz Problems & Warranty Issues 0 11-24-2003 09:06 AM
