Old 03-24-2020, 10:31 AM #16
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a spectacular aura about Bad Luck has a spectacular aura about Bad Luck has a spectacular aura about
Real Name: Patrick
Originally Posted by 4'running'26 View Post
Hmm...ok. That kind of makes sense from my limited experience.
Any "easy" adjustments that can be made or can this only be adjusted from the flexplate end of things, thus requiring the transmission to be dropped? Toyota did this, I sure as hell hope the'll back it up if an intensive tear-down is needed.
Starter replacement or full starter rebuild is your solution. There are no adjustments for the flywheel.
2000 Limited V6 Auto E-Locker
Old 03-24-2020, 11:34 AM #17
4'running'26's Avatar
4'running'26 4'running'26 is offline
4'running'26 is on a distinguished road
I just replaced the starter (used OEM) and that sound was not present until after the broken flexplate was replaced. It doesn't seem reasonable that the starter went out that fast?
--'00--Red--295k--Auto--SOLD
--'99--Green--204K--5spd--TOTALED
--'00--Black--156K--Auto--
4'running'26 is offline   Reply With QuoteReply With Quote
Old 03-24-2020, 04:01 PM #18
Real Name: Patrick
Real Name: Patrick
I'm assuming "used OEM" means that it was a used part. If that's the case then I'm not surprised that it's failing/failed.
Old 03-25-2020, 04:17 AM #19
19963.4lsr5 has a spectacular aura about 19963.4lsr5 has a spectacular aura about 19963.4lsr5 has a spectacular aura about
To me the only way a starter can make any noise is if the trans and engine are not aligned.
The alignment dowels if there should maintain the alignment. If not your trans can clock clockwise or counter clockwise.
belt , columbia , defintiely , flexplate , timing
3rd Gen Timing Marks for Timing Belt Replacement FTW1996 3rd gen T4Rs 4 10-01-2015 04:00 PM
Timing belt? or Timing chain? MNguns General Discussions 3 06-24-2013 12:06 AM
Timing Belt Tensioner: Should I replace it when doing the timing belt change? Lugnutz 3rd gen T4Rs 14 05-12-2011 12:58 PM
Aisin timing belt kits vs. Dayco Timing Belt Kits drz Maintenance/Detailing 1 10-11-2010 06:42 PM
