Old 03-18-2020, 05:06 PM #1
ptsailing ptsailing is offline
ptsailing is on a distinguished road
Lower ball joint parts number confusion
I am curious if anyone has pressed in new lower ball joints? I am getting the OEM LBJ from Longo Toyota and in JWaldz post about oem part numbers he lists Driver (Left) Side LBJ: 43340-39465 and Passenger (Right) Side LBJ: 43330-39585 as the part numbers (checked with the Stealership and they are $119 each. These part numbers show a LBJ with a metal arm and the ball joint already pressed in. I figure the metal part on my rig is fine (its a NV and CA car....0% rust)
I also found Lower Ball Joint 43340-39245 on the Toyota parts factory site that seems to be just the LBJ for $70. Id love to save $50 per LBJ if all I have to do is press in the LBJ and re use the metal arm.
Does anyone know what the difference is between these part numbers? The Stealership sites (I have been to 4 or 5) all show an exploded view of the suspension but no photo of an actual part.
Can I just press in a new LBJ?
Any help would be greatly appreciated
Lower ball joint parts number confusion-screen-shot-2020-03-18-2-05-03-pm-png  Lower ball joint parts number confusion-screen-shot-2020-03-18-2-07-19-pm-png
ptsailing is offline   Reply With QuoteReply With Quote
Old 03-18-2020, 05:14 PM #2
The cheaper ball joint is for the 2nd gen ('89-'95) and doesn't work in our application.
The diagram you posted is a second gen front suspension...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-18-2020, 05:34 PM #3
AZBub's Avatar
AZBub AZBub is offline
Real Name: Chris
AZBub will become famous soon enough AZBub will become famous soon enough
AZBub's Avatar
Real Name: Chris
Here is a list of 3rd gen parts. don’t forget to order 8 flange bolts. This is from camelback toyota. If avoid Amazon as they are having an issue with counterfeit pets lately..
Lower ball joints don’t get pressed in. Uppers do and honestly is a pain in the ass that’s why in other threads you have started in regards to all this I suggested upper arms like JBA cause they are more affordable and the adapter was easy to press in. I pressed in factory UBJs once. Never again.
The JBA adapter was engineered to work specifically to fit in the press you would rent. Not sure if that was on purpose with them but it made it super easy
You can get away with Autozone outer tie rods or Napa higher quality stuff. I had them on and they did pretty well. I just replaced them yesterday after 3 years and the still didn’t have any slop.
AzBub Build2000 Toyota 4Runner Highlander, 4x4, E Locker. 4:30 gears. TRD Taco springs on Tundra 5100s. FJ80 8 wraps/Monroe economy rear lift.
AZBub is offline   Reply With QuoteReply With Quote
Old 03-18-2020, 06:29 PM #4
HiLife HiLife is offline
Your part numbers in the first paragraph and lbj pic are correct for 3rd gens.
The part number 43340-39245 is for 2nd gen left lbj. The illustration chart is also for 2nd gen.
That "metal" plate is part of the lbj on the 3rd gen and is considered as one unit.
Don't forget to order the bolts too to go along with the lbj's!
Old 03-19-2020, 01:06 AM #5
OK that makes a lot of sense....mind you the dealership site quotes that part number as being for 4runners from 1989 to 1998....so my 1997 3rd gen fits in that range...hence why I was confused.
I really appreciate you guys....glad I checked with ya'll so now I know which are the correct parts to order.
Old 03-20-2020, 01:07 PM #6
Bowtierebel Bowtierebel is offline
Bowtierebel is on a distinguished road
I will be replacing my lower ball joints soon on my 2000 4x4. I did buy the OEM Toyota ones. I didn't think about needing new mounting bolts as mine look fine. Why would it be necessary to replace the mounting bolts?
Bowtierebel is offline   Reply With QuoteReply With Quote
Old 03-20-2020, 01:14 PM #7
If they have been over-torqued in the past, they have lost their strength. There is a risk that they will snap (and there have been a few examples on here of that happening).
Old 03-20-2020, 02:15 PM #8
I bought new bolts just to be on the safe side.....for 8 bolts it was $10.....$10 worth of piece of mind and insurance.
Old 03-21-2020, 12:32 PM #9
tx_shooter's Avatar
tx_shooter tx_shooter is offline
tx_shooter will become famous soon enough
tx_shooter's Avatar
A lot of the LBJ failures are actually bolt failures due to age/condition. The abuse these bolts take are two fold: over/under torquing and shear force impacts with pot holes/bumps/high speed driving abuse. The bolts are ~$10 and are cheap insurance to make sure your rig stays looking good.
tx_shooter is offline   Reply With QuoteReply With Quote
Old 03-21-2020, 07:39 PM #10
AZBub's Avatar
Real Name: Chris
AZBub's Avatar
Real Name: Chris
Don’t forget the blue locktite on the LBJ flange bolts.
Old 03-22-2020, 12:05 AM #11
And dont forget to put the proper stretch on the lbj bolts by properly by using a torque wrench set at the required foot pounds.
Old 03-22-2020, 06:28 AM #12
Thanks for the replies! I certainly agree that $10 is well worth additional safety insurance. I will be ordering some today. I haven't looked to see what the grade of these bolts are, but I'd guess they'd be M10.9, similar to an SAE grade 8. I wouldn't have thought about these bolts shearing, especially with there being 4 on each LBJ mounting in relatively close proximity to each other. This is another great reason that this forum can be invaluable by being able to learn from others experiences. I am definitely replacing mine too. My rig ha's 267,000 miles, so age, fatigue, possibly having been over torqued in the past are the reasons I'll replace them. Someone has done some work on this T4R prior to me getting it and the workmanship was not the best. Thanks!
Old 04-28-2022, 06:57 AM #13
germankokubu germankokubu is offline
germankokubu is on a distinguished road
Hi, Charlie. Thank you for sharing your knowledge. I am from argentina and I am looking for the lower ball joints of my hilux (same as 2nd gen T4R). Part numbers are:
- 43330-39315, Right side
- 43340-39245, Left side
LHS ball joint is no longer available as genuine OEM part in my country. I would like to know if the RHS fits the left side, as the parts seem identical. Moreover, there is only one aftermarket part for both sides. Thank you!
germankokubu is offline   Reply With QuoteReply With Quote
Old 04-28-2022, 09:21 AM #14
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
The Lower Ball Joints are side-specific and are not interchangeable.
They are mirror-images of each other, identical to each other but flipped around (just like the upper control arms, to name one example).
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 04-28-2022, 10:04 AM #15
Thank you Cl4rk for your response. It is true that the lower ball joints of your truck are mirror images of each other, but in the older model they are visually identical (not flipped around).
Lower ball joint parts number confusion-lbj-jpg
ball , lbj , lower , numbers , part
Upper Ball Joint/Lower ball joint replacement Tigerfan86 4th Gen T4Rs 1 03-03-2020 03:10 PM
Lower Ball Joint OEM Part Number loarmistead 4th Gen T4Rs 8 08-17-2018 09:39 PM
2006 upper ball joint number? Can only buy with complete arm? sajer 4th Gen T4Rs 6 08-26-2016 01:42 PM
2003 Lower Control Arm/Lower Ball Joint replacement Wahoo96 4th Gen T4Rs 5 01-30-2015 02:16 PM
Lower Ball Joint Replacement Questions, Tacoma Parts, and Securing Bolts. TheFriZ 3rd gen T4Rs 7 06-13-2014 09:26 AM
