The axle side stud is that entire piece youre looking at. There is no sleeve in that video. I believe the bushing size on those are 3/4. What is the I.D. on your new lower shock bushings? What shocks/ part number are you trying to install?
__________________ 2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8 RR/ Anonymous Fab lower uniball McNeil Racing fenders Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps 315/70/17 BFG KO2 on Robby Gordon wheels 231mm TBU / Wheelers SS lines MStudt rear swaybar links Tom Woods driveshaft Satoshi K&N FIPK w/ AFE dry filter Borla Pro XS URD short throw shifter & Ellis Precision shift knobs Uniden PRO 520XL & 3' Firefly on custom mount Prinsu full rack Baja Designs Squadron Sport Sae & combo beam lights Paranoid Fab switch panel with Ram mounts Extended rear diff breather 01-02 tail lights Stubbs HD-SKO sliders Any 7 Offroad gas tank skid @Assburns custom tube front bumper Nguyen Works swing out bumper FROR rear links
Never seen that before. I'm guessing who ever installed the previous shocks had bushings with the ID too large and put that sleeve on there to compensate instead of getting the correct size lower shock mount bushing.
__________________ 1. Black 2002 SR5 4x4 5vz:Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling) 2. Black 2001 SR5 4x4 5vz: stock 3. Black 2018 TRD Pro (wifes):Armor Custom bolt on rock sliders (U-bolts)
Thats bizarre. I couldnt see the sleeves outline over the stud mount in your video so it appeared to be one solid piece. Good job! Is there a sleeve on the stud mount on the other side of the axle?
