Old 03-19-2020, 02:43 AM #1
Luke325i Luke325i is offline
Luke325i is on a distinguished road
Compress rear shocks in order to tighten?
Procomp es9000 matched to my truck by 4Wheel Parts
Im finally at the stage to stack the bushings and install them but i cant get a thread to get the nut to grab onto!
Note, these bushings came with the shocks, so im doing something wrong
Here is a gallery of the bushing orientation, and a pic once placed into the upper mount location
Truck has wheels off, jackstands on axle.
How am i going to squish these enough to expose some threads?
Luke325i is offline   Reply With QuoteReply With Quote
Old 03-19-2020, 04:28 AM #2
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
I'm assuming you already have the lower shock mount bolt threaded on. If so, did you try jacking the axle up to compress the shocks enough to get the nut threaded?
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 03-19-2020, 08:46 AM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
It might be too late for this part, but the easiest way to install rear shocks is in this order:
1. Mount bottom shock bolt
2. Cut shock strap and let it slowly decompress into the top mount
3. Secure top mount
If that's no longer possible, you'll want to compress the shock by carefully jacking up the side of the axle you are working on. Doesn't need to be much.
326WHP 347TQ
Old 03-19-2020, 09:33 AM #4
I can re-compress them easy... Ive tried it with lower connected, and lower disconnected
I think im going to have to use a jack, you're right
Old 03-19-2020, 04:00 PM #5
Real Name: Jerod
Real Name: Jerod
Yeah and once you have the nuts started on both side, bring the vehicle back down on the ground and then finish tightening it down. You'll have a lot more thread to work with then.
326WHP 347TQ
grab , nut , thread , truck , wheels
Struggling to tighten rear 5100 jeredcollins 3rd gen T4Rs 16 04-10-2019 01:53 PM
Rear shock bolt wont loosen or tighten RKA100 3rd gen T4Rs 8 05-21-2015 05:05 PM
Urgent Help! Rear tundra 5100 install (how to tighten top nut??) KurtL 3rd gen T4Rs 6 10-04-2014 03:59 PM
Tighten the rear lift gate? PolkManiac 4th Gen T4Rs 3 08-06-2009 01:59 PM
How to tighten rear gate - squeaking noise PolkManiac Problems & Warranty Issues 1 04-07-2008 11:14 PM
