12-04-2013, 05:48 PM
electric to manual t-case mod?
I have a 1997 Limited edition with the electric actuator on the transfer case. Me list to say the actuator has bitten the dust!... With the prohibitively expensive replacement part I am forced to wonder if there is a cable or lever or otherwise actuated workaround that would give me a manual solution to this automatic problem?
Cheers!
Ron
12-04-2013, 06:21 PM
I ahve not done this before, but I would think it would be easy to swap from the electric to manual J-shift transfer case. The are a direct swap ad far as fitment is concerned.
The only thing that comes to mind immediately is the location of the vehicle speed sensor and it is located on your current t-case. If not, you could simply yank yours and throw in a manual j-shift case. If your VSS is on your t-case, there might ba little mroe to this.
I don't have any personal knowledge on VSS equipped t-cases as mine is not one of them.
2005 GX470
3.4l A340 Automatic to R150F Manual Transmission Swap
http://ttora.com/forum/showthread.php?t=159482
12-04-2013, 07:19 PM
Location: Stationed in Camp LeJeune, home is Conover, NC
If I'm not mistaken, all 4Runners use the ABS system for the speed. This might not be true on the older 3Rd gens, but I know it is on the newer ones.
That said, you CAN use a tacoma transfer case on a 4Runner. That's what I was running. I need to get another one. Thats how I run my speedo.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
12-04-2013, 10:45 PM
Ah, you may be correct. I was recalling the details from threads over on TTORA for Tacoma's. I think they may have the VSS on some of their t-case's.
That said, yeah, you certainly can use a Tacoma case. My transmission now is out of a Tacoma, and my t-case is my stock 4runner one.
If you take a look at my transmission swap thread in my sig, there is a picture of an electric shift case out of a Tacoma. Just be sure not to get one of those.
2005 GX470
12-04-2013, 10:49 PM
You had a taco transfer case but you tacoed it, so now you have a 4runner transfer case...
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
12-04-2013, 11:33 PM
Hence why I said I need another. Inchworm, ATCM, is not making the Lefty anymore.... :-((((((
12-04-2013, 11:34 PM
I can tell you with certainty that my 97 gets it's speed signal from the wheel sensors... No change after the re gear proves it... And I'm in the same boat I'm about to ditch this electric tcase because the servo keeps sticking
97 Limited 4x2 ---> 4x4 (SOLD)
SS 1.3 | ToyTec | RadFlo | Aussie | SOR | AOR | CBI | DC Power | Rigid | Alpine | Audison | JL Audio | Second Skin
2020 TRD Off Road Premium
King | BFG | Rago | AudioControl | AudioFrog | JL Audio | Dynamat
12-05-2013, 02:01 AM
I had the multi-mode case in my 02 runner and swapped to the j shift case once I destroyed my electric shifter. The only things I had to do to mine is swap both drive shafts since the multi mode case is longer then the stock and also some crafty wiring to get the front diff to shift properly and to get the dash lights to work.
2002 SR5 4Runner
Auto, 4x4, Camburg Long Travel, Relocated Dual Batteries, 34" KM2, Custom Armor
12-05-2013, 08:41 AM
Thanks for all the help guys! I've been looking around and it doesn't seem too difficult to find a "j" pattern transfer case out there... This is all a great insurance plan however I am some what surprised that there isn't some slick manual way to actuate the shift Rod in the transfer case once the motor has given up the ghost...
I'm going to dig into it a little further this weekend and will report back to here with my findings!
cheers and thanks!
Ron
05-12-2017, 09:01 PM
Hey Broker,
I just did a electric to manual transfer case Swap in my 1996 Limited SR5 4Runner(E Locker).
I have everything installed and it all works perfectly but 4 HI. When I move the shift lever to 4 HI it feels like the transfer case shifts but the front axle does not engage. I do not get a light on the dash showing me that it is engaged either. I have all of the sensors(switches) in the right spot on the transfer case.
When I shift to 4 LO it all works great. Light comes on and the rear locker works as well.
What did you do to your rig electronically (wiring) when you swapped the transfer case?
09-10-2017, 06:07 PM
Has anybody figured out if the swap is doable yet? I have a 97 Limited and just picked up a 97 SR5 with the "J" T-case.. can I swap them straight across or is there issues? Thanks
07-17-2018, 11:15 AM
I need to know what craftiness My actuator is stuck i have the flashing lights on my 01 and i cant get it off ( pause lol) so im seriously considering swapping to a j shift but need to understand the scope of wiring work.
as well what drive shafts did you use?
07-17-2018, 11:53 AM
Our speedo works of abs sensors. Only need 2 of them to work. Can either be both front or both rear ones.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
07-17-2018, 08:10 PM
Folks, if I am understanding this right, he is trying to fogure out if there is some simple way to rig up a lever or cable to manually actuate the linkage(s) originally manipulated by the electric servo. He is not, however asking if it is possible to swap the entire T-case out with a J-shift version.
Basically, he is looking for the $5 solution, as opposed to the $500 solution (and I certainly don't blame him! I'd honestly kinda like to know as well...).
Mine: 2002 SR5, Lifted, Armored, and Accessorized on 33s. Build Thread
Hers: 2016 Quicksand TRDP, Lifted 2" on ~32s.
07-17-2018, 08:14 PM
@ Lindenwood
, that was 5 years ago.
