Old 03-20-2020, 11:56 PM #1
BostonJon BostonJon is offline
BostonJon is on a distinguished road
‘99 fog light wiring diagram
Hi-
Does anyone have the fog light wiring diagram for a 1999? I have the diagrams from 2002, but I think the lighting circuits were slightly different.
Thank you!
BostonJon is offline   Reply With QuoteReply With Quote
Old 03-21-2020, 11:35 AM #2
heat's Avatar
heat heat is offline
heat is on a distinguished road
heat's Avatar
Here's the '00 version. I couldn't find one for the '99
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 03-21-2020, 03:38 PM #3
J.A.'s Avatar
J.A. J.A. is offline
J.A. will become famous soon enough
J.A.'s Avatar
Originally Posted by BostonJon View Post
Hi-
Thank you!
I have the diagram here Toyota 4Runner Highlander Electrical Modifications Fog Light Mod
J.A. is offline   Reply With QuoteReply With Quote
Old 03-23-2020, 05:55 PM #4
Pedrojr80's Avatar
Pedrojr80 Pedrojr80 is offline
Pedrojr80 is on a distinguished road
Pedrojr80's Avatar
Any one know how to down load the pic on here? Lol.99 4runner foglights wiring.pdf
1999 4runner limited 4x4 millenn silver with rear elocker! with front toyotec boss front suspension, rear boss shocks, rear 3" ome 890 coils, front cbi bumper without grilled hoop, 315x12.5x16 bfg, old school 16x10 wide wheels, front IPF 968 6" lights.
Pedrojr80 is offline   Reply With QuoteReply With Quote
Old 03-23-2020, 06:50 PM #5
Pedrojr80's Avatar
Pedrojr80's Avatar
Hey Heat how did you manage to get that pic in here like that? Lol i being trying for the past 1/2 to get my wiring picture on here, but i cant get it to work. I have used google drive, iCloud drive, and even send the pic my email. Any help? Even tho im trying to help by providing with the wiring diagram thanks.
Old 03-23-2020, 07:04 PM #6
heat's Avatar
heat's Avatar
You're trying to display a .pdf file. It's not an image file, though it can be
downloaded from your post.
Software here lets you attach "Valid file extensions: bmp doc gif jpe jpeg
jpg pdf png psd txt zip" but doc, pdf, txt, and zip aren't image files and won't
display.
I opened a pdf on my computer, took a screen capture of the page I wanted,
loaded it into an image editor, and exported a jpg. That's what I attached here.
Old 03-26-2020, 12:03 PM #7
phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold
Hi-
Thank you!
The DRL and non-DRL versions are different... need to know which one you need.
'16 Honda Odyssey
Old 03-30-2020, 12:56 AM #8
Non-DRL please.
Don’t think DRL was standard in the US back then but not sure about that.
Old 03-30-2020, 04:05 AM #9
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a jewel in the rough TheDurk is a jewel in the rough TheDurk is a jewel in the rough TheDurk is a jewel in the rough
TheDurk's Avatar
Non-DRL please.
It was in Canada.
My '99 is paper, so I'll wait on Charlie.
My Backyard Frame Swap
Old 03-30-2020, 02:39 PM #10
Originally Posted by TheDurk View Post
It was in Canada.
So is mine!!
'16 Honda Odyssey
Old 03-30-2020, 02:50 PM #11
TheDurk's Avatar
TheDurk's Avatar
Originally Posted by phattyduck View Post
So is mine!!
OK. I fired up the scanner.....
Old 04-20-2020, 09:11 AM #12
Thank you to everyone who assisted here. With the help of these wiring diagrams and some info on other threads here on the forum, I was able to troubleshoot the issue to a faulty bulb with an internal short between the filament (+ lead) and the base of the bulb (- lead). Given that the car is 21 years old and I was installing the OEM fog lights for the first time, I had assumed that there was a cracked/shorted wire somewhere between the connection under the front bumper and the fuse box. I did not expect the issue to be caused by a brand new Philips bulb. Upon closer inspection of the bulb, I noticed that the cloth sheathing on the positive lead was worn away near the area where it is soldered to the filament. Therefore, this positive connection was arcing with the base of the bulb when the two should have been electrically isolated. Always start with the simple stuff!
Thanks again!
diagram , fog , light , slightly , wiring
Wiring Diagram for 4 Rigid 6" Light Bars to one switch MNT4R 5th gen T4Rs 0 10-07-2016 12:38 PM
Wiring Diagram for Light Bar, Rear Lights, and D2s RedStripeRanger 5th gen T4Rs 17 10-23-2015 02:25 PM
2005 4runner running board light wiring diagram Greenbean80 4th Gen T4Rs 2 04-11-2015 10:40 PM
Stock Rear Fog Light Switch Wiring Diagram cpguy33 Engines / Suspension / Wheels / Tires / Audio / Accessories 18 11-11-2006 07:43 PM
