Old 03-21-2020, 06:05 AM #1
Ghostrider Ghostrider is offline
Ghostrider will become famous soon enough
Roll forward while in Park
Hoping this is normal. Washed the truck on level ground for the first time in years (previously had a steep driveway). While standing on rear wheel to get to roof I noticed I could roll the truck froward about an inch or two. Is this considered normal?
Ghostrider is offline   Reply With QuoteReply With Quote
Old 03-21-2020, 07:38 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Yes but don't do that, it is stressing the pin in the transmission.
That pin holds the entire weight of the vehicle.
Its why we have a Parking Brake or what some call and Emergency brake.
When one parks on an incline one should first set parking brake Then move trans shifter to P, this keeps the weight and stress off the pin. When getting back in, the reverse needs to happen, hold foot brake then release parking brake, again to keep the stress off the pin.
Does the pin break often, probably not, but I hate when I see someone park on an incline then you can see when they let off the brake and the vehicle moves that inch or so until it bumps into the pin, ouch.
Luck....
Old 03-26-2020, 12:21 PM #3
All automatic transmissions will do this. Set your parking brake!!! (it adjusts your rear brakes on this particular model)
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-26-2020, 03:40 PM #4
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing will become famous soon enough GhostRing will become famous soon enough
GhostRing's Avatar
To get even more retentive, these are my steps:
Come to stop in desired location, and engage parking brake
Shift into N and let foot off brake. Vehicle should not move
(if vehicle still rolls, have your PB serviced asa-freakin'-p)
Then shift into P. Turn front wheels into the curb
Now you are using the pawl as the backup, letting the parking brake do the real work.
And if everything somehow fails, the vehicle doesn't just roll down the street!
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 03-26-2020, 07:40 PM #5
HiLife HiLife is offline
Yup, if your loading up on the parking pawl to hold the initial vehicle load on a grade, you'll be able to feel what kind of bad stresses the whole parking pawl is up against when you take the shifter out of park.
Old 03-26-2020, 08:07 PM #6
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
All the replies were on point for this topic. ALWAYS, ALWAYS, ALWAYS!!!!! use your parking brake. Do not let the weight of the vehicle rest on the parking pawl for two reasons. #!, you could end up shearing the parking pawl and then you'll be crying at the expense to fix it. #2, your rear brakes stay in adjustment by regularly using the parking brake. The rear brakes only do around 25% or your braking, but you will notice the difference in braking power with them way out of adjustment.
Old 03-26-2020, 08:10 PM #7
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You really don't need any servicing for the parking brake other than regularly using it to keep the rear shoes adjusted. If you're only getting 7-9 clicks from the parking brake handle, it's adjusted correctly. The times I've of heard of people having problems is the people who live in the rust belts of the country and their bell cranks freeze up due to corrosion.
Old 03-26-2020, 09:10 PM #8
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
well I want to add to the "always use your parking brake " to add weather permitting.
when you get 2 feet of snow, and temps dont get above zero for weeks at a time the parking brake cables etc DO stick. Not just on 4runners but many many cars up here.. and having your brakes frozen up is no fun
Otherwise, when it gets back to above freezing here, I always use my parking brake
inch , normal , rear , roll , truck
Roll Overs and Roll Cages Bumbo 4th Gen T4Rs 19 02-18-2019 01:51 PM
"Roll" in park VolcanoT4R 3rd gen T4Rs 10 10-19-2015 09:06 AM
Car does not roll forward when stopped and put in Drive spoiler900 3rd gen T4Rs 6 04-30-2015 10:08 AM
Pay it forward? IsItMe? 5th gen T4Rs 3 05-11-2011 01:12 PM
